Results 1 to 1 of 1
Thread: Weld in MK1 VR6 Conversion mounts now available
    These will be available in the shop shortly.
    MK1 VR6 conversion mounts
    This is without question the best way to mount a VR6 into the MK1 platform. Yes it requires some welding and the chopping out of the original drivers mount, but once done you have the following benefits over the bolt-in kit:
    1. 5 mounting points over the 3 mounting points (including 2 on the front crossmember)
    2. Engine is mounted in a more natural position, meaning;
    3. Standard 100mm Driveshafts can be used, so custom driveshaft lengths not needed.
    4. Gearbox is not so far over to the left hand side, so the your tyres will not rub the end of the gearbox
    5. Available for 5 and 6 speed gearboxes (6sp will need custom length driveshafts as per a 1.8T or PD with 6sp)
    Click image for larger version.
