VW Caddy  (AKA VW Rabbit Pickup) Forum
Go Back   VW Caddy (AKA VW Rabbit Pickup) Forum > General Topics > Mk1/A1 Caddy
Reply
Thread Tools Search this Thread Display Modes
  #901
Old 05-06-2009, 10:51 PM
mycoolhair's Avatar
mycoolhair mycoolhair is offline
Caddy Apprentice
Garage
Quote:
Originally Posted by sitrials View Post
how many attempts to make air tight? LOL
not dissiing your fabrication but i know trying to make something airtight can be a right bitch
first if welded right
stick a compresor on of the holes bung the others and create a little pressure, then paint the joints with weak washing up solution by far the quickest way to garantee its air tight.
much better than water cos its under pressure and gas will escape through smaller imperfections than liquid
your likly to find some "pin holes" on the stop start of the welding.
ive been making boat tanks for years like that, never had one leak yet
most that ive repaired go in the heat affected zone around the welding so would recomend in future to bend where possable.
am most impresed with your make it fit theroy and keep up the good work
  #902
Old 06-06-2009, 03:35 PM
sitrials's Avatar
sitrials sitrials is offline
Caddy Crazy
Garage
Send a message via MSN to sitrials
i found some inspiration for you to finish! http://videos.streetfire.net/video/m...olf_189813.htm
__________________
CADDY GONE - BUT NOT FORGOTTEN!
  #903
Old 06-06-2009, 04:31 PM
powernut's Avatar
powernut powernut is offline
COTY Winner 2009
Garage
great replys guys ,,, (regards tank/ 2 attempts , i had 2 tiny pin holes , lol ,, only found this with soppy water and filing the tank with compressed air , broke my bluetooth so no pics at mo....made and fitted the feul lines too ,and started on fuel pump fitting,
  #904
Old 06-06-2009, 05:59 PM
powernut's Avatar
COTY Winner 2009
Garage
sorted bluetooth ,lol had to mean dam microwave too lmao ,, i must be a jack of all trades
  #905
Old 06-06-2009, 06:07 PM
christian's Avatar
christian christian is offline
Caddy Apprentice
Get some mk2 golf fuel lines on thare, unless there brakes?
  #906
Old 06-06-2009, 06:45 PM
powernut's Avatar
COTY Winner 2009
Garage
Quote:
why would i need mk2 fuel lines ?these should be fine ,8mm feed/return pipes
  #907
Old 06-06-2009, 08:26 PM
christian's Avatar
Caddy Apprentice
Mk 2lines are long and plastic can run them through the chassi
  #908
Old 06-06-2009, 10:06 PM
powernut's Avatar
COTY Winner 2009
Garage
i see what u mean ,, little late now ,,
  #909
Old 08-06-2009, 11:17 PM
powernut's Avatar
COTY Winner 2009
Garage
well managed to sort a few bits this after , first made some fuel lines for the caddy
next deceied to chop the fuel flap out the boady
rare site lol, inside ,rot free
then went around the other side and chopped another hole out for the to refit the feul flap
not bad for a trail cut ,there was a slight gap so ,thought id add a filler rod , and welded up nicely
quick weld up
and grinded off
then oppss first thought id welded it wrong because its upside down ,must have got a bit carryed away , but i pref it to open this way lol ,little late now anyway
then a quick filler neck start on the pipe
  #910
Old 09-06-2009, 07:02 PM
christian's Avatar
Caddy Apprentice
You move fast
  #911
Old 09-06-2009, 07:16 PM
sitrials's Avatar
Caddy Crazy
Garage
not fast enough as we'd all like to see this thing move!
first outing at GTI INTERNATIONAL DOWN THE STRIP!!!
__________________
  #912
Old 09-06-2009, 08:39 PM
caddyrage's Avatar
caddyrage caddyrage is offline
Certified Caddy Nutter
Garage
Send a message via MSN to caddyrage
Mental workmanship mate. You are talented at making crazy things.
I want you hurry up and finish so we get to see the next mad thing you do
__________________
92 caddy 2L 9A 16v, http://www.vwcaddy.com/showthread.ph...ight=caddyrage
83 golf gti 2L PL 16v, http://www.vwcaddy.com/showthread.php?t=39015
www.fendubbers.co.uk
OZ TURBO ET33 WANTED
  #913
Old 09-06-2009, 10:38 PM
christian's Avatar
Caddy Apprentice
You need a 4 poster ramp . want to buy one ?
  #914
Old 09-06-2009, 11:07 PM
powernut's Avatar
COTY Winner 2009
Garage
cheers guys ,,, that was yesterday afternoon lol , no updates 2day bin a tad bisy ,4 poster be nice , problem is room to use one and i dont think the nosey neiboughers would be happy lol, oh and finding yes more dam rot , so getting fed up of cutting/welding ,seems on going and not getting anywere
  #915
Old 11-06-2009, 11:44 PM
powernut's Avatar
COTY Winner 2009
Garage
right 2day noticed the camber sticks out more on the fronts to the rears dose this wheel look ok to you guys as i think the botom of the wheel is towing out to mutch ?
as after i was looking at the rear they had way too mutch inwards camber , maybe ok for corners ,but not very good for scrubing tyres off , and what a dam stressfull trying to algin the wheel, after getting it a tad lower i carnt risk anymore , so altered all the arms and also insurted a smaller box and stick welded them for extra strengh
  #916
Old 12-06-2009, 09:56 PM
mycoolhair's Avatar
Caddy Apprentice
Garage
Quote:
Originally Posted by powernut View Post
is this not a bad place for the tank from the point of veiw of an accident.
i know the minis have the tank in the boot
have you put any thing in to minimise the chance of poping the tank in the event of a rear ender.
just a idea.
  #917
Old 13-06-2009, 03:29 PM
powernut's Avatar
COTY Winner 2009
Garage
there is the rear bumper hangers/ rear towbar ,/suport mounts,.etc , as i really need it as a counter balance for weight to ratio , as i was going to fit it to one side of the car but thought better at the rear , mind if it gets hit hard enoegh least im in the front , unlike if i fitted a tank behind the seat extra ,, sooner have it safer away from the driver seat tbh,
  #918
Old 15-06-2009, 11:57 PM
powernut's Avatar
COTY Winner 2009
Garage
not mutch to add due ringing around for a reasobable insurance , bit more welding and passenger seat frame started
old seat frame removed
seatbelt mount inner and outer sill nicely welded up
new suport welded in place and just started makeing new seat frame to fit my other seat
  #919
Old 16-06-2009, 12:22 AM
macetheace's Avatar
macetheace macetheace is offline
Caddy Crazy
Garage
Send a message via MSN to macetheace
Such a quality thread, love it dude
__________________
Re-build Pics Here
  #920
Old 16-06-2009, 07:12 AM
powernut's Avatar
COTY Winner 2009
Garage
cheers pal , its 6am so theres time todo a few bits today i reckon lol ,carnt beat a bit of homemade fun ,,,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
DTO Garage vBulletin Plugins by Drive Thru Online, Inc.
All graphics, layout & content are Copyright © of Just Caddys 2003-2009
