Results 1 to 5 of 5
Thread: Rocker cover
    Jul 2010
    Stanley Durham
    3,687
    Rocker cover
    I have just replaced the rocker cover gasket as it was leaking a bit near the air box, I have put a new gasket on with some gasket seal, tightened it down, let it dry overnight, I have just drove 42 miles and it is now leaking all over the place,
    Any ideas
    Cheers
    Dec 2017
    United Kingdom
    47
    Quote Originally Posted by sandancer View Post
    Any ideas
    Cheers
    Firstly, what engine is this on?
    Secondly, where did you put the gasket seal?
    Caddy MK2 1.9 SDI (ALH swap incoming), Seat Inca 1.9 SDI, Static Polo Estate 1.9 TDI (AHU), Aired Golf MK4 1.9 PD130
    Jul 2010
    Stanley Durham
    3,687
    Quote Originally Posted by jwrb View Post
    1.6D
    In the same place as the last one came from
    Aug 2005
    Rochester UK
    1,900
    Over tightened?
    Mar 2004
    York, United Kingdom.
    767
    I use these one piece gaskets. You need to use different bots to hold down. i generally put a too long bolt in with a nut and washer on shank, tighten bolt home then tighten rocker with the nut.
    https://www.ebay.co.uk/itm/VW-Golf-M...kAAOSwrTVbQz9s
    A Caddy is for life not just for Christmas
