Thread: K14 to k24 turbo swap AAZ
    Devon
    28
    Hi Iíve picked up a k24 turbo from a mk2 golf gtd and was going to fit it to my aaz which has a k14 fitted I understood that the turbo should fit without to many problems. I know the oil return is different and thatís fine the problem Iím having is that the turbo hits the inlet manifold? Is this normal or have I missed something? There was also no gasket between the exhaust manifold and the old turbo? Again is this normal? The only thing I can think to do is make a spacer to move the turbo back a little? Any advice would be good thanks
    3,857
    I didn’t have a gasket with my k24, if you wanted I suppose you could make one from a thin piece of copper.
