Results 1 to 1 of 1
Thread: mk1 caddy rear brake hose
    Apr 2008
    under a car
    31
    May be of use to folks:
    Found it a bit of a pain finding/ordering these as what is usually offered is standard length brake hoses around 200mm long but these are not what you need.
    What you need:
    The brake hoses that connect from the centre of the rear axel to the copper pipes above are the following type
    465mm long (although you could use upto 100mm longer if needed)
    with female(internal) M10x1 threads on the ends
    Lucas part no ghp465
    vw 291611775
    or
    borg & beck
    bbh6709
    https://www.ebay.co.uk/itm/VW-TRANSP...72.m2749.l2649
    https://www.ebay.co.uk/itm/VOLKSWAGE...72.m2749.l2649
    brake retaining springs
    4d0 611 715b
