Thread: New drive shaft - how much grease?
    May 2013
    USA
    117
    A new driveshaft as the old one has torn boots and a lot of grit in it as a result.
    How much grease to put in the thing when I install it?
    Really load it up? Pack it into the recess? Or just the bearings and not a lot more?
    Nov 2013
    Cheshire
    78
    I usually smother it round the bearing and swivvely bits then just use whatevers left in the sachet they give you with the CV joint. Usually looks like the right amount.
