Results 1 to 20 of 39
Thread: 02a GEARBOX LINKAGE
    Sep 2013
    stoke-on-trent
    47
    02a GEARBOX LINKAGE
    HI I need a 02a gearbox linkage and shifter,cables etc, I have installed 1.8 16v kr in the caddy with a peal box for hydraulic clutch any help would be great
    thanks Knobby
    4,486
    Do yourself a favour and get a 02J setup instead. You’ll need the in car shifter cables/cable bracket on the box and the mechanism tht bolts into the box. It’s a direct swap and it is a million times better than the 02A setup.
    Sep 2013
    stoke-on-trent
    47
    HI Pal which car do i source parts from i assume you cant get new
    thanks Knobby
    Mar 2004
    York, United Kingdom.
    762
    There used to a link for a German company that made adaptors for 020 linkage to 02A box.
    A Caddy is for life not just for Christmas
    Sep 2013
    stoke-on-trent
    47
    thanks Knobby
    5,007
    Quote Originally Posted by knobby View Post
    thanks Knobby
    Your best bet, is from a late 5 speed mk4 golf, either diesel or petrol.
    4,486
    yeah, buying new would cost a fortune. either head to a breakers or ebay. i got all the bits i needed for about £80. yeah i'm pretty sure like Elroy said, mk4 golf 5 spd. just make sure the shifter mechanism looks like a golf putter.
    you need the shifter that looks like this
    https://www.google.com/search?q=02a+...Skw4jqyqx_BZM:
    and just make sure you get the in car mechanism, cables and cable mount
    Sep 2013
    stoke-on-trent
    47
    Thanks for the help
    knobby
    Sep 2013
    stoke-on-trent
    47
    HI mate I have located some parts just wanted to be sure that they will fit my 02a box (forgot to say thats the box i have)
    thanks Knobby
    Sep 2013
    stoke-on-trent
    47
    HI Mate can i ask how you routed the gear shifter cables
    thanks Knobby
    4,486
    Just use a hole cutter to cut a hole in the bulkhead. Run them through and fill with a. Grommet
    Sep 2013
    stoke-on-trent
    47
    Cheers pal
    Sep 2013
    stoke-on-trent
    47
    HI Pal i purchased an 02j selector and it will not fit in my box the diameter of the shaft is bigger any help would be great
    thanks Knobby
    Sep 2013
    stoke-on-trent
    47
    HI Chaps i purchased an o2j selector from a mk4 golf and it will not fit my box the diameter of the haft is bigger, any help would be great
    thanks Knobby
    did you take out the whole "tower" using the two bolts?
    4,486
    Yeah like 13 said, you need to remove the 02a tower from the box using the two bolts and the 02j one just drops in its place. Regarding the shaft that comes out and slots right in the box you have twist it so it lines up, also there’s a sort of loose metal cup thing, tht needs to be twisted so the little half moon shape tab sits in its locating point
    Sep 2013
    stoke-on-trent
    47
    HI Yeh I have the whole thing out i will send a picture (if i can ) of my 02a and the 02j sitting next to itthumbnail (1).jpg
    thanks Knobby
    Sep 2013
    stoke-on-trent
    47
    As you can see from the picture they are different ? unless i am missing something they only possible explanation is the selector i got is the wrong one
    thanks Knobby
    4,486
    i'm presuming the one you just bought is the one on the left?
    4,486
    take a picture of the underside of your gearbox, should be a little vw logo with 2 bolts either side
