Results 1 to 9 of 9
Thread: tdi lack of power
    glos
    201
    tdi lack of power
    hi guys
    this is a strange one as no codes coming up whatsoever and literally one min it can drive perfect then the nxt it way down on power ive tried 2 new ecus and made no difference,fuel inj pump fine as been tested,ive done fuel filter air filter,
    I was wondering if could be throttle sensor or maf I have swapped maf but borrowed off a friend so not sure if gd any ideas be handy oh and def no vacline or hose issue
    just swapped throttle sensor no difference
    horncastle
    301
    When it loses power have you tried switching it off and back on again?
    west midlands
    3,772
    glos
    201
    yea turned on off no different
    def not vanes as turbo new
    South lincs
    19
    I can't remember if these have an EGR, but on on the PD in my car, the EGR being caked up was causing this problem. A delete kit fixed it nicely.
    As you've recently done a pretty major job (turbo replacement), it's worth going round and making sure you've not got a loose pin in an electrical plug or an vac hose giving a poor connection.
    Have you got the means to do a fault code read?
    glos
    201
    yes all boost hoses fine,all vac lines fine
    yes no codes whatsoever
    ive noticed on tickover its fine but if you rev hard a few times it will start juddering and sounding rough and smokey then will settle back down
    egr deleted already and cleaned out inlet while off
    633
    Start with the simple stuff and change the fuel filter
    glos
    201
    done that at start lol
    looks like the issue is a shot cat
