Results 1 to 7 of 7
Thread: 1.8t conversion - temp sender
    Jun 2017
    Wooton Bassett
    48
    How do people get there temperature gauge working with a 1.8t in a mk1 caddy?
    The temp sender on the engine is linked to the ecu so I can't use that to work the gauge on the cluster.
    Use a MK3 Golf/T4/Ibiza sensor 357919501A
    Jun 2017
    Wooton Bassett
    48
    Great thanks that's a simple fix.
    Tonight issue is the oil pressure sensor. I've got no light with the engine off and a flashing light with the engine running.
    Do I have to do a sensor change for that as well?
    To satisfy the mk1 clocks, you’ll have to use a low and high pressure mk1 sensors.
    Jun 2017
    Wooton Bassett
    48
    Ah ok can't work out how that's meant to work. I think I just put a relay in the circuit to change the normally open sensor to a normally closed signal.
    Quote Originally Posted by BUGMAN View Post
    You remove the MK4 oil pressure switch, and the blank on the filter housing and replace them with the 2 MK1 switches
    Google mk1 golf oil pressure sensors and how they work and you’ll understand
