Results 1 to 9 of 9
Thread: pinion bearing
    187
    pinion bearing
    I am rebuilding my steering rack with a quaife quick rack, and i need a new pinion bearing number is f-81985 anyone know where i could get one from?[
    Picture of it.
    ATTACH=CONFIG]33050[/ATTACH]
    Thanks!
    187
    figured it out, used a bike bearing, #6804 if anyone has trouble finding it.
    607
    Was it easy to swap over? I’ve been looking at doing the same conversion
    187
    i didn't swap it over, i used a different pinion, i put the pinion in the freezer and bearing in the oven for 20mins, went on like a glove.
    607
    more the installation of the quafe parts
    187
    haven't installed it yet, its fairly simple though. just have to put the new tie rods back where the old ones where.
    187
    All Installed, simple to do. pretty much brand new now.
    DERBYSHIRE
    4
    Was this on a factory rack?
    I've got a Quaife kit to fit, but I've got a Meyle rack. There is the odd bit of information about repro racks needing bearings spacer, but nothing definitive.
    Need to get the turbo downpipe off before I can investigate, but that's not happening at the moment!
    187
    the quaife kit is to fit the original rack, it could be different for a repo one.
    They used a repo one by mistake for the mk2 golf, and apparently the kit doesn't fit the original without modifying, so i dare say you're gonna run into issues.
    Pickup a original rack if i was you, i saw one on ebay last week might still be there.
