Results 1 to 10 of 10
Thread: How to replace rear turrets/leaf spring mounts
    108
    in need of some help, i need to replace the inner turret sills, + turret and rear leaf spring mounts, how do people go about it, lining everything back up?
    15,460
    http://www.vwcaddy.com/showthread.ph...-game!)/page17
    post 653 on?
    not sure where you mean by inner turret sills
    108
    http://www.retrofication.co.uk/innersillturret.html these things,
    I was going to buy the last turret but it sold just as i was about to buy it
    I see how al did it, but doesnt say how he re aligned the turret?
    108
    So this was my idea, cut out the turret, then cut out the sill and stitch/seam weld them back on, looks like they are stitch/spot welded on originally, not sure how much these flex so i don't know if seam welding is the way to go?
    I've measured up as much as possible, but if someone knows a better way i can go about this, i'll appreciate it very much!
    This is the most logical way for me?
    Any insight will be grateful!
    Photo wouldn't rotate
    4,821
    Why you so hung up on things flexing from spots welds, there’s some big hp mk1 caddy trucks on standard rigs
    108
    i'm not, im saying, if it needs to flex and i seam weld it, it'll just crack, so does it need some sort of flex or can it be solid. stitch welding all the seams is like a free rollcage with the added benefit of less cracking as it spreads the load.
    I seem to be the only one doing it, should be a huge difference in handling.
    4,821
    Quote Originally Posted by Nick-Nack View Post
    Are you planning on racing the caddy on a track and slinging hard around corners?
    108
    yes.
    4,821
    yes.
    Tell us more, what’s your intended suspension/ engine set up
    108
    nothing major for now as i just lost my job, just the basic stuff and maybe a 4 point front subframe to connect the wishbones together.
    Has nobody changed the rear turret sills apart from AL??
