Results 1 to 8 of 8
Thread: body under the body?
    206
    so uhh.. i just cut my sills off, and on one side it appears the original body is under the body?
    it does look like they've welded in new metal surrounding it, do i cut out their metal and try put the body back on? who the hell does something like this???
    Don't mind the rust... yikes, i'll try fix that..
    206
    i'm starting to think i've bought the worst bodged caddy on this forums... can anybody top this?
    1,599
    Mine had about 2 inches of filler there... If I were you I'd cut it all back and do it properly
    206
    yep, mine had about that much there too, yeah i want to, just don't really know how to yet. ill figure it out!
    Romsey
    592
    My first build thread was full of surprises. It is now a trailer for Dubmonkey ...
    South lincs
    18
    A lot of pattern sills are formed as an oversill. To be fair, as long as the original rust is totally removed and and cavity and exposed edges rust proofed, it's not too bad a way of doing it as the original metal is much thicker than the pattern crap.
    I wouldnt panic to much. All Mk1 Caddys are rotten in that area!
    As they rot from the inside out, you dont know until its to late. But if your lower seam is swelling due to rust then it will be the same as this when you start cutting into it.
    Thats the reason why I started making all these sections in the first place, so that you can repair it all properly:
    http://www.retrofication.co.uk/innersillturret.html
    http://www.retrofication.co.uk/rearinnersill.html
    http://www.retrofication.co.uk/inner...forcement.html
    And depending if you can save the turret or not
    http://www.retrofication.co.uk/MK1su...47803171A.html
    and even a filler panel if it has spread that high
    http://www.retrofication.co.uk/fillerpanel.html
    See my VRT build thread, start from post 653!
    http://www.vwcaddy.com/showthread.ph...-game!)/page17
    206
    Thanks Al, i was looking into a few of those panels, im going to do some more investigating and cutting, from what i can see right now it's just the ends that are rusted which i can hopefully cut off and weld some new metal on, i think i might need 1 or 2 of the rear leaf spring mounts though as one has been welded and it's falling apart at the back.
    Is it too late to get a partial refund on the caddy lowering kit i ordered? its been just over 2 months but i'm going a different route now, did send an email but i guess you are very busy.
