Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Mk1 Caddy - AHU Build
    Bristol
    644
    Does anyone know the part numbers for a shorter belt and pulley to delete the mk3 PAS pump?
    May 2018
    United States
    7
    Nice Caddy you have there
    Bristol
    644
    The caddy has progressed a bit now.
    The 1.6 petrol has come out, generally that was not too much of a battle thankfully.
    The 1.9TDi AHU engine was stripped down out of the donor. Sad times, it's been such a reliable workhorse:
    The engine out and back cover exposed before it was cut to expose the holes for the new mk1 engine mount:
    Removed the the PAS pump, belt, pulley etc, new cambelt kit, back cover trimmed to fit the new mk1 engine mount:
    Trimmed the plastic cover around the mk1 engine mount:
    Fitted the O2A gearbox conversion mount to the back, bit fiddly finding some suitable allen key bolts as it was so tight to the gearbox (though later found a bag of bolts in the box of goodies that came from Retrofication that I think were for this purpose - whoops):
    In the engine went, generally quite smoothly:
    Found a problem that the oil filter was much larger on the mk3, and it left no space to be able to get it out in the future. The engine was lifted up again and the mk1 oil filter was put on what was smaller:
    Other mk1 conversion gearbox mount, generally a great kit:
    Mk3 hose trimmed to get the heater matrix pipework to fit in the mk1:
    Petrol taken out the mk1, and diesel replaced:
    More trimming of the mk3 hoses to connect to the mk1 reservoir:
    Various bit of other bits connected up, and this is how it sits at the moment.
    Used the retrofication kit ready for the hydro clutch. The how to guide was very useful:
    Couple of questions you guys might know?...
    There seems to be two options for the coolant reservoir pipe - is one better that the other? Or just take a pick and black off the other?
    I'd like to use the original intercooler pipework to keep it looking like a factory install - this leads both pipes to the right of the radiator, and I have bought an intercooler that will suit. There isn't much space though between the radiator and battery to get the pipes past? Has anyone welded in a new battery tray at 90 degrees to create more space? Someone else I met was using a much smaller battery from a Suzuki Jimny on an AAZ conversion which was starting up ok?
    What route have been taken their O2A cables back? Is it better through the firewall, or beneath?
    Still a way to go, but the mk3 is now scrapped and more space freed up...
    Bristol
    644
    Quote Originally Posted by hgiblin View Post
    For others benefit... turned out different belts are not needed.
    Mar 2015
    United States
    10
    I ran my shifter cables, through the floor and over the steering rack.
    I'm still getting the truck sorted but it seems to work well.
    Bristol
    644
    Quote Originally Posted by SeanDiesel View Post
    This looks smart. Can a mk1 centre console fit over that?
    Bristol
    644
    Happy New Year's all.
    So bit of an update...
    My friends been doing the clever bit with the wiring... it's getting there and a lot been stripped from the loom now.
    There is a problem with the driveshafts though - I have bought new from the retrofication, but the boot is clashing with the strut, and on the passenger side when the nut is tightened it all locks up solid? Anyone else experienced these issues?? Any ideas?
    Any help with questions above appreciated too.
    You need to tickle the hubs with a grinder to allow clearance for the bigger cv's. There's a thread on it in the how to section of the forum.
    http://www.vwcaddy.com/showthread.php?42579
    Bristol
    644
    Quote Originally Posted by rusty_nuts View Post
    Thanks! That solves the binding then, anyone experiences the strut and boot clash?
    Bristol
    644
    She lives....
    Some progress on the caddy - finally reached the point that it could be taken on a short test drive!
    • Larger 9 inch servo and master cylinder is installed, and brakes bled.
    • Cooling system finished - I don't have any pics but ended up needing to make the lower pipe up with two silicone 90 degree bends and a coupler
    • Glow plug relay finished off
    • Drive by wire pedal set up finished. A mk4 golf TDi pedal has been used, with a bracket made up to hold it in place. To start it, I bought the left hand drive bracket, and modified from there - it's not necessary if you have good fab skills... but thought it would be a good starting point.
    I didn't take enough pictures on the way, but here are a few...
    Temporarily mounted the mk3 golf cable gear change, if can be mounted properly later on when I know where to place it around the centre console:
    Speedo cable installed in to the O2A box:
    Temporarily removed the intercooler for now:
    New brake light switch positioned:
    Bristol
    644
    The Mk3 golf immobiliser was bypassed using an immobiliser emulator (eBay job). The car starts and runs ok, but the ODI port is not working to read any faults on the car?
    One place said that this is because the immobiliser control box is missing - is this correct? And does anyone know if just the box needs to be there, or all of the ring / key etc too?
    Any help would be appreciated
