Results 1 to 3 of 3
Thread: Serious suspension rattle in the front end.
    Mar 2018
    Huntsville, AL
    14
    I have had a serious suspension rattle in the front end since I purchased the truck. It sounds like the front end is about to damn near remove itself, even when I go over the smallest of bumps. The driver's side is worse than the passenger. When I had it up on the stands yesterday I couldn't find anything that felt even remotely loose. Also, the steering column bearing keeps sliding out of its housing and I cannot get it to stay. Is there an easy fix for that?
    Jul 2013
    Bognor
    529
    Suspension top mount ? (Under the bonnet)
    15,674
    Is there any bush inside the top mount?
    Broken suspension spring?
    Does your steering column have all the bushes and springs it should? Mine was missing the bottom spring which lost the tension and made the shaft loose in the column
