Results 1 to 17 of 17
Thread: Sucking in air
    Stanley uk
    1,960
    Sucking in air
    Mk1 pickup 16d,
    I have just recently started having trouble starting my truck, after having a look it is sucking in air from the top of the fuel pump return, tried tightening all the jubilee clips and tightened everything connected with the pump, the injector pipes are fine and it is still sucking in air.
    any ideas
    Cheers dawn
    Stanley Durham
    3,663
    Ok I'll look at it for you
    Do not know why
    I,v suffered enough I married you LOL
    3,835
    Might not be the cause but I once repaired a mini digger and struggled getting it to start as it was sucking air. Eventually I found out I’d over tightened one of the jubilee clips
    10,277
    Having the same prob with my T4.
    There was a slight leak from the fuel lines. Fitted new ones, won’t start. Turns out it’s the seal around the fuel pump. Needs to be removed, posted away, repaired, sent back, refitted.
    Fuck I hate living on this island!
    Stanley Durham
    3,663
    What seal on the pump, as I have a spare pump for spares, we have changed all the pipework and checked all the fittings.
    10,277
    Dunno. My engineer mate could tell you if I wasn’t in Inverness.
    Aug 2009
    lancs
    1,418
    Do you mean you can see bubbles in the return?
    Most of the pump external pump seals would show a fault by leaking. Front seal can suck air. Injector return pipes can be come porous and are cheap and easy to change.
    Air can enter the pump and hence the return via the feed system anywhere from tank to pump.
    Fill a bottle with fuel and attach to inlet feed union, see if it runs.
    Stanley Durham
    3,663
    We have changed all the pipes, there is no leaking diesel at the pump, and still sucking in air
    Aug 2009
    lancs
    1,418
    Tried it running from a can and pipe sat under the bonnet?
    How do you know it's sucking air?
    17,885
    Leak down pipes - replace them all for a few quid with 3mm petrol hose, replace the blanking cap on no 1 injector as well.
    The filter white fitting can crack as well - check that.
    Front seals rarely go on bosch pumps.
    Pumps will pull air without leaking any diesel - they leak diesel when the throttle shaft or pump head seals go (but don't suck air)
    10,277
    I got your msg Reggy.
    Mine originally started with a leaky fuel pipe - the one under the van. It left a small stain everywhere it was parked for a while. Had some new lines fitted and that’s when it started to fcuk up which, I believe, is a broken seal in the pump.
    Stanley Durham
    3,663
    Quote Originally Posted by rolo View Post
    No I have not tried the can and pipe set up.
    I have got clear pipe on and you can see the air bubbles coming from the pump return pipe
    Stanley Durham
    3,663
    I have got a skoda filter on and it only has an in and an out
    Stanley Durham
    3,663
    Sorted it, we renewed the injector return pipes and no more bubbles.
    17,885
    Quote Originally Posted by dawn64 View Post
    Quote Originally Posted by sandancer View Post
    Quote Originally Posted by rolo and regcheeseman
    change the leakdown/return pipes
    621
    Personal theory...Fuel gets hot....cools down overnight.... the tank then has lower pressure than the outside as its partly sealed. The air then gets in through the weakest point.
    The leak off pipes.
    seen a few bad start issues cured by changing the leak off pipes, I have 7mm round spring clips on mine with the thought that it cant hurt
    Stanley Durham
    3,663
    Reg, we have just moved and I am working my way through all the car part boxes, I found some and put them on but they obviously were not new, so went and got some new ones and now it is all sorted.
    My fault for being a tight twat LOL
    By the way it is her truck and I don't want to spend money on it LOL
