Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 41 to 60 of 129
Thread: 2.0 8V MK1 Caddy Quick build (hopefully)
    Tremendous effort and thread so far - you are doing a great job.
    You know that you can pull the filter out of the middle of the fuel tank if your tank is full of crap.
    Keep up the progress!
    Where do you want to race? Drag? Hill climbs?
    200
    Thanks 13!
    What is this filter you speak of, is it the circular thing in the middle? i finished electrolysis on the tank today and its filled with crap yup, i was thinking steaming it?
    hill climbs would be cool, was just thinking of track days, but that wouldn't be for a while till i got comfortable with the car, fastest car i've driven is a 75hp lupo followed by a 60hp up
    Quote Originally Posted by Nick-Nack View Post
    I am quite sure my 75hp Up! is the slowest car on earth
    I thought i had some pics.... let me look.
    200
    almost finished the sill and rear turret, got a small bit of sill to finish and put the turret on, but here's what ive done in the last 3 days.
    Repo sills are very frustrating, especially when they're shaped like a banana.
    Fixing a previous patchwork...
    Seam sealing under the turret panel and welding it in
    Finishing off some bits before putting sill on
    This took a while...
    Still having grinding to do, but its on there, its not perfect, but its pretty difficult to get it perfect as it's a repo to start with.
    Nov 2010
    Devon
    460
    You're doing a fantastic job with the welding and fabrication work. Its in a similar state to how mine was. I did all the work to mine myself and it was the first project i had ever done so reading this thread takes me back to the pain I endured fixing up mine. Keep at it and it will be well worth all the effort in the end.
    200
    thanks a lot andy, i did read your thread with all the rear end and sill work, that's where i got the confidence from, so thank you for that i wish i could say i did it all on my own, but i had help from a friend for most of the front end work, so i can really understand all the hard work you did as it was tough enough with 2 of us!
    200
    turret and end piece of sill done today! 90% complete, just grinding welds back and painting then it's done!
    accidentally grounded down the turret while removing the seized in bolt a while ago, so sandwiched 2, 2mm plates together as a replacement
    Welding in a back piece behind the turret to stop crap getting in behind it
    welding it back in after careful measurement, also put in 1mm thick strips along side it so i'm not just welding to the panel directly.
    Cranked up the welder, welding thick metal is so much easier than thin metal..
    Attached the end piece of the new sill to my old sill, slightly different so had to bend them to fit eachother, but got there in the end.
    also attached a strip at the end of the inner sill to the inner rear arch, should add a lot of strength.
    Trick i learnt, put new metal ontop of old that you're replacing then cut both same time to get perfect 1mm gap.
    Went very slowly welding it in, didn't want to warp panel, so dabbed damp rag after every couple welds.
    All i have left to do is grind the welds back then paint it! rinse and repeat on other side.
    it's not perfect, i'll have to use body filler, but it's strong, which is what matters the most, and rust free!
    Tomorrow and tuesday i should be able to get a lot of work done on the other side.
    Nov 2010
    Devon
    460
    I'm pleased that my build thread has helped people out, it makes it worth all the time and effort writing it up if people are reading it and learning something from it. I really need to get it up to date now all my photos have returned since photo bucket have done a u turn on the third party hosting ban. Keep up the good work on yours, I do like to check in regularly to see how its coming along.
    200
    sills and turret all done! Accidently cut the wrong side of my brand new turret sill... so had to weld it back on
    Also put some plates in the chassis rail next to the turret to add some strength.
    Enjoy 28 pictures.
    I have the inner rear arches to do, rear valance, tidy up the cross members and do the rear leaf springs, getting close!
    Jun 2013
    kent
    156
    awesome work! where did you get your rollover jig?
    200
    Thanks buddy! got it from here https://www.rolloverjigs.com/product/standard-jig-185/ it's pretty good, but could do with more holes to lock it in place.
    200
    got some panels today from Al, This is going to be fun...
    200
    spent a month on the rear end, everything is done, the caddy is 95% rust free! was a lot of hard work, i hate grinding...
    Pics galore, didn't take many of before pics, i forgot...
    before pics of the bed.
    Starting off removing the bed
    Removing rust in arches, and the welds..
    Welding up chassis rails and arches
    Other side
    Grinding down cross members/chassis rails and adding new ones in.
    Grinding original paint from sidewalls
    then the sketchy part of flipping car upside down and balancing it on wheels while i remove the rear end and leaf spring mounts..
    Painted
    had to do rear valance as it had awful patch work, forgot to take before pic...
    Moving onto bed, fixing up the bits i cut out earlier, were a bit of a pain.
    Preparing bed and plug welding it in!
    Adding strip to bulkhead end, and making 14 end pieces
    Welding it in!
    Very happy with it! got a few little bits to tidy up, but i think i'm pretty much there, welding wise.
    Next is body filler which im dreading, then paint.
    Nov 2010
    Devon
    460
    You've done a fantastic job with the rear end and load bed panel. Well done for doing the tapered end pieces on the bed, I chickened out of doing that with mine cos it looked too difficult to make it look neat but you have done a great job with yours.
    1,892
    Awesome work mate,pretty much rebuilt the whole caddy from what I can see of it,you certainly won't regret it a few years down the line thats for sure....carry on with that standard of work and its gonna be a top caddy,hats off to you
    grimsby
    132
    Nice work dude, those bed tapers look good, well worth the extra effort
    200
    Thanks a lot guys! the tapered end pieces weren't too difficult but definitely worth the extra time. Originally i wasn't going to do the bed, but it was definitely worth it, if its on the spit, may aswell do it properly while it's there.
    I do plan on having it look decent, but not perfect. what i am focusing on is mechanical side to be mostly all new if possible, want it to be like a brand new car.
    200
    Finishing up a few last bits of welding as my friend wanted his welder back after 4 months which was pretty nice of him to leave it with me that long.
    no more arches... they are gone, and i have a ton of room for some chunky tyres!
    Rear end of arches were both rusty, so cut that out and repaired it.
    Axle needed saddles back in original position, happy with the welds. (still need to cut off the bodged axle flip saddles)
    Putting back on the mount for the brake lines to go through, as far as i can remember it was something like this..
    Made new brake compensator bracket for the cross member as old one was rusted, ive no idea if i need this as im running mk2 golf rear brakes but it won't hurt being there.
    Welding back in the exhaust hanger as i put in new crossmember
    And finally seam sealing the underneath, used rubberised seam sealer, but switched to tiger seal and it's a lot better and lasts much longer!
    and a sneak peak at the next task in hand... never done it before, but it's going alright.
    Not sure how long it's going to take, but as soon as body filler is done i'm going to etch primer the whole thing.
    Will be painting for first time aswell, hopefully it turns out alright.
    grimsby
    132
    its coming on dude, hats off to turning your hand to the painting, not sure i have the confidence for it.
    200
    thanks, took a little longer than i'd liked but its better than i anticipated. by paint, i kinda mean etch primer and underseal the bottom.
    might paint the engine bay and cabin, but i don't think i'll do the whole body, not in my dusty shelter.
    only one way to learn, and that's to make mistakes
