Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 21 to 40 of 136
Thread: 2.0 8V MK1 Caddy Quick build (hopefully)
    206
    Got a little bit of work done today, did a bit on my own aswell.
    Finishing up stitch welding the bay, still needs a few more bits, mostly done though.
    Got 1 of the chassis rails welded in, looks really good, super strong, maybe too strong. Also need to remember to drill in some drainage holes just in case too.
    Attacked a rust hole all on my own, and plated it up, felt pretty good to finally do something on my own!
    I lost 1 of my magnets into the abyss of the rust hole, forever lost.
    cut out the rust and plated the jacking point, been using 2mm thick steel, so very strong.
    That's all i managed to do, pretty happy with the work i did for i think my 3rd or 4th day of welding!
    I'll grind some of the welds down as they don't look the best, but that's the beauty of it!
    1 thing i wish i did was clean and red oxide as soon as i weld an area up, some of the stitch welds are starting to rust, 1 thing to note.
    Tomorrow im working on my own, doing the other chassis rail and cutting out the other jacking point, little nervous, but i'll give it a go!
    Romsey
    593
    You'll do fine. It's all looking good.
    206
    i think i'm going to just make sections for the other jacking point and few holes, i won't touch this, if i mess it up, the wishbones wont lineup properly.. i've no idea where i'd even start with it. such a tricky spot.
    Romsey
    593
    I really struggled with that spot. I did it in 2 parts to ensure that one part was always secure. Then I tidied it all up.
    Romsey
    593
    There's a some good advice given on #102 on my build thread.
    I tried to add it to this post but to no avail.
    206
    i think i'm going to avoid that piece.. i got some great info from your thread though, thanks a lot! this seems like a job for my friend, he did say to double plated it, but im thinking it needs a thinner plate over the top of that aswell, like this:
    previous owner kind of did that on the other side, ill also measure how much thread is on each bolts to see if they match up.
    206
    Today i made a mistake, i was welding and the welds were spluttering, they looked ok, and i thought nothing of it, it wasnt till my last weld that i realised.. the gas wasnt on
    So my clothes are covered in holes and my arms have burn marks all over them, i think the welds are strong? i held them on a bit longer than usual, hit it with a hammer a bunch and it held so hopefully everything is ok..
    With that said, here's the pictures..
    Made plate and welded in (had to use a big magnet as i lost all of mine)
    grinded welds down, looks.. ok?
    Cleaning the jacking points and spot welding them back in
    Kinda disappointed i made the mistake, but now i know i won't make that mistake again..
    can someone comfirm my welds are strong? i was melting the edge of the 2mm thick metal so i assume it should still be very strong.
    i did go over a few of the welds when i turned the gas on aswell, maybe i need to do that again? im not sure.
    Have to ask why are you stitching the seams ??
    206
    Strengthening the chassis so it handles better, i presume. i'm just going with the flow of what my friend tells me, he built a mk2 escort and it's pretty amazing.
    Yeah it was what we used to do to rally cars years ago
    206
    i can't see it doing anything negative, other than possibly cracks showing up if you hit something hard, the caddy was in an awful state, bodged everywhere.
    Not too worried about wrecking anything, i think it'll be super strong when it's done, just a little bumpy!
    I dont see any problem with it just had to ask im the champion of overkill lol
    206
    haha, yeah, we probably made it maybe too strong, especially the chassis rails, even with a few tacks it didnt move at all. you live and you learn, not the end of the world.
    Apr 2010
    138
    that's coming on nicely, did you notice the loose pipe in the fuel tank? same happened on my caddy sport and it would cut out when it was less than 1/2 full. if you need a chassis rail I have one I cut off a breaker also have the exhaust tunnel with handbrake tubes P1000237.jpg
    206
    yeah i managed to get the pipe out! i made my own chassis rail just got to weld it in, i'll figure out the handbrake tubes, but how do i take them off? do they just twist off or what? Thanks for the advice!
    206
    Got the last chassis rail done today, floor is looking pretty good, few bits to do and the sills then it's finished!
    welding in the strips for the chassis rail to sit on
    Ran out of welding wire, burnt through about 3kg of it in a week, not too bad!
    Got some red oxide to brush on £30 for 5litres! great stuff floor is looking really good now
    Was getting late so couldn't clean up some areas to paint, but its almost there, chassis rail needs some welding as we ran out of wire, should be done tomorrow.
    Very happy with the progress, theres some stuff to do in the engine bay, big rust hole in the floor in the cabin then i think it's onto the dreaded rear..
    206
    Didn't like the way the other inner front arch was done, so cut out the 2 crappy patches and started making plates, stitch welded the turret aswell.
    Trying to stitch weld the turret but the metal was just rotton, so cut that out
    Smoothed off some welds from previous owners patch, the only one im going to leave in and hope and pray its decent behind it..
    Will probably go over it tomorrow, also forgot to show we welded 1 plate in, but didnt manage to get the other one done.
    Brother was using poly disc on rear quarter to bare metal, doesnt heat it up much or distort it, so very handy thing to have! only took a few hours!
    Used roller to paint it with red oxide, came out pretty great!
    Painted both inner front arches, painted it on thick
    Forgot to take pics of some things, finished the chassis rails, bottom floor is almost done, need to fix the sills and then it should be good!
    few bits to fix on the inner arches still, but very close to being done.
    Next is finishing the engine bay stitch welding and a few rust spots, then the cabin needs some work from welding the floor.
    Few more days hopefully!
    206
    Well, it's been a while... been busy doing odd bits and figuring out things. here's a lot of pictures of the work i've done over the last month.
    Grinding down to bare metal
    Attachment 32536
    Attachment 32537
    red oxided
    Grinding windscreen surround to bare metal and repairing rust
    Fixing it all up
    rear window bulkhead
    Attachment 32533
    Attachment 32534
    Attachment 32535
    Finishing up the inner front arches
    Stitch welding cabin
    Cutting out sills and fixing up the rust
    Rear sills
    206
    206
    worked on the rear turret sills today, got quite a bit done, hoping, possibly tomorrow i can finish it all and even weld on the sills, but that's pushing it.
    Need to clean the turret up a bit but it looks like it's going to fit back in place just nicely.
    I'll see if i can finish it tomorrow, but im happy with the work so far looks so much better.
    Anyone have any tips on removing the surface rust from the tight spots? my dremel is pretty awful.
