Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 75
Thread: Project.... "instant death"
  1. #41
    The busa motors got some torque!
    Its been nice knowing you
  2. #42
    1,397
    You should have gone tl1000
  3. #43
    15,189
    Quote Originally Posted by Al View Post
    Thanks Al
  4. #44
    May 2003
    Scotland
    13,755
    Is this for that barrow rod thing you were on about?
    That's not gonna happen though, coz your a prick! And I'll stay here just to annoy the fuck out of you.
  5. #45
    15,189
    Me? That was your ridiculous idea!
    Think I've run out of room....
  6. #46
    15,189
    There really are no plus points to bike engine are there?
  7. #47
    Jul 2005
    North Devon
    17,853
    Quote Originally Posted by 13 View Post
    Of course there are, they make a lot of power from a small compact shape and are unit constructed with an integrated clutch and gearbox
    Being lightweight and designed with modest torque output they ideally suit installation in a very small and light vehicle.....
    like a motorbike for example.
    Stop pissing about with that buggy. put the engine in a decent chassis.
    Having watched a bike engined go-cart run 12 second quarters, why not do that, then annihilate a certain red truck at the pod.......
  8. #48
    15,189
    Haha, very good.
    Lol, a 1998 106 120hp gti is all I need for that.
    Shame they are all gone.
  9. #49
    4,546
    Quote Originally Posted by regcheeseman View Post
    Haha, that wouldn’t be difficult at the present
  10. #50
    15,189
    What's the female end of a splined shaft called? I need something to grip my gear shifter
  11. #51
    Jul 2009
    Cheltenham, UK
    9,716
    spline coupling?
    Mk1 '91 1.6 GTD build so far...
  12. #52
    Jul 2005
    North Devon
    17,853
    Use the bit that's already on there - typically a simple bell crank with a spherical bearing/rose joint?
  13. #53
    15,189
    Isn't that part of the rear set (in terms of flogging tat I don't need) spose I could just not include it....
  14. #54
    Jul 2005
    North Devon
    17,853
    Depends - you normally get a gear lever with a spherical bearing attached and that's it, don't be giving stuff away that you need. Can you google for the rearsets to get a picture?
  15. #55
    15,189
    a day of messing about with drills n stuff... stage 1 - 50x50 box - mitered into a few sizes (30 degree cut and also 45 degree cut) depending on position. I'm going to use the longer ones at the front where i have removed more steel underneath to save double weight.... or something... stage 2 - box linished to a nice profile then drilled 10.5. stage 3 - 25mm bar, cut to 44-45mm length, linished to size, then drilled to 10.5m10 10.9 bolts to finish. Mounts with next stage - bracing for subframe and engine end - 5mm plate, welded onto the end of 32mm tube, again 10.5 hole for bolts. Subframe progressing. bracing next T45 for the new rear end No going back now!! rear end has been detached Spent a while messing about notching the tubes... exact length TBC Think this time i'm going add bracing. never really liked how it was originally, in my structural engineering mind... will I hit the tyres though....? Also need to consider the seat belt brace too. Air box might be in the way Trial position Mor T45.... Going to make a kind of triangulated tube thing to hold in the motor More soon
  16. #56
    You need to do some recycling mate
  17. #57
    15,189
    What makes you say that
  18. #58
    503
    Back of the pick up possibly
  19. #59
    15,189
    That's my useful box collection and storage area. Just drive it out when I need space
  20. #60
    4,546
    So you haven’t decided to take it apart again, for the sheer hell of it.
