Righto, managed to get a couple of hours in this week!
First I spent shovelling gearbox oil filled cat litter off the ground...
The second I spent attempting to get my clutch sorted out.
I have 02A slave, T4 master, 02J box, HEL all new parts between pedal and the original dmf clutch setup on my 1.8t.
I tried
just pumping the pedal
Pump and hold
Messibleed/pressure bleeder
Then all of above with the slave disconnected and raised as high as I could
No air is coming out, just new clean fluid. Pedal feels firm
Clutch doesn't do anything, except chip teeth oFf the gears if I try and engage.
Going to try bleeding once more tonight, then what?
Thanks lads!
