Results 1 to 20 of 23
Thread: 02A slave, T4 master, 02J box
    15,460
    Righto, managed to get a couple of hours in this week!
    First I spent shovelling gearbox oil filled cat litter off the ground...
    The second I spent attempting to get my clutch sorted out.
    I have 02A slave, T4 master, 02J box, HEL all new parts between pedal and the original dmf clutch setup on my 1.8t.
    I tried
    just pumping the pedal
    Pump and hold
    Messibleed/pressure bleeder
    Then all of above with the slave disconnected and raised as high as I could
    No air is coming out, just new clean fluid. Pedal feels firm
    Clutch doesn't do anything, except chip teeth oFf the gears if I try and engage.
    Going to try bleeding once more tonight, then what?
    Thanks lads!
    4,811
    Is the master cylinder being pushed in enough... full travel?
    15,460
    i did wonder that but I think so.
    not exactly sure what to test in the system. cant really test the clutch that i can think of? and cant really test any components without buying new, which might be necessary
    i was a bit surprised how much fluid movement is in the resevoir
    1,553
    Have you taken the clutch off ? If not it maybe a case of the clutch is stuck from standing
    15,460
    Are u in fact suggesting that ye older shit heap hasn't moved?
    No I didn't take it off, (didn't want to find anything heart breaking) good thinking
    15,460
    Uugh that means box out
    Was mentally prepared though
    1,553
    Or start it in gear with your foot on the clutch if you have a long drive way
    15,460
    I did try that last night, it does go forward
    What would that achieve?
    Could I have forgotten something like clutch release bearing etc? What would that do? Don't think I did.... Or put it in wrong?
    1,553
    If the plate is stuck to the flywheel it should free it. Can't see how the clutch pedal would be firm if the thrust bearing was missing.
    15,460
    Think u could be right tontoe, didn't even know this was a thing.
    Poor starter motor has Had a hard time, but not free yet. Might be a tow down the road next
    17,875
    Think I've been here before a long time ago, was a random bolt stuck in the pressure plate or something equally stupid.
    Gearbox off time mate.
    England
    3,282
    Lift one side with a trolley jack,and start it in gear.Never had a clutch that didn't come unstuck after a short while.
    15,460
    What do u mean by lift one side? Jack a wheel off the ground?
    1,553
    Quote Originally Posted by B1G VR View Post
    Good idea Kev. Much better than mowing down the neighbours yes 13 lift one front wheel. Unless you have an lsd fitted
    England
    3,282
    And make sure the clutch pedal is held down,while you are doing this.
    15,460
    No joy, box on way out.
    Bet it's the hydraulics after all this.....
    17,875
    Of course it will be, but you'll not know until you've wasted hours pointlessy removing the gearbox.
    15,460
    4,811
    Looks like it's been sat at the bottom of the pacific for the last ten years.
    15,460
    Fuck you. shit box.
