Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
Thread: Fuel Cooler Location
    What sort of temperatures are we talking about here?
    Because the diesel will be that much hotter do I need to replace the clear plastic fuel lines?
    No
    Any ideas if I need to replace this semi clear plastic piping due to heat?
    It's got an OD of 8MM and fits snugly in the plastic clips along the bottom of the chassis, so presumably if I need to change the line I need new clips or hard line instead?
    Attachment 30815
    Just join to what you have with rubber fuel injection hose
    1,612
    I would guess up to about 70C? I really don't know, but it must be reasonably hot if there's a cooler right?
    Cheers Al!
    1,612
    If I cut the plastic pipe to install the fuel cooler am I going to be able to flare it so it doesn't pop off?
    IGNORE, obviously return is low pressure, shouldn't need to flare it. Just need to make sure the supply side is flared
