Results 1 to 7 of 7
Thread: Shorter drive shafts mk1 with mk3 subframe HELP ME PLEASE
    May 2016
    Southend
    78
    Hi guru's I am at witts end with me Caddy.
    So its running Mk3 VR6 and I was advised to narrow the track using mk3 TDI wishbones, drive shafts etc.
    All was going well until I chassis notched and extended the balljoints.
    This solved bump steer and gets me really low but stopped me adjusting the camber on the strut and top mount, seemed drive shafts were too long. I need a bit of camber to tuck the wheels under arches
    So in my wisdom I re ordered the original VR6 wishbones
    This allowed me to get camber and tuck the wheel. It's way too excessive and I really need another option. Shorter driveshafts with the TDI wishbones?
    So is there another set of drive shafts I can use or will I need to have them cut down?
    Desperate now as missing all the shows and hot days I should be enjoying my caddy, Spent so long trying to get these wheels to fit under the arches, So far I have widened the arches, extended and widened turrets, Airbagged the struts, Changed running gear (twice)
    Chassis notched, raised ball joints, Flipped tierods and more.
    Any expert advice greatly appreciated
    May 2016
    Southend
    78
    Any ideas anyone?
    The problem is, is that you have shortened the distance between the gearbox and the hub due to your setup.
    Your going to need to try and find a short shaft or cut n shut one. But before you do that I would put the tdi wishbones back on as the VR wide track looks ridiculous on a MK1
    May 2016
    Southend
    78
    Yeah I agree it looks terrible. The TDI ones are going back on.
    All this headache for those wheels and I am starting to go off them.
    I read somewhere that a circlip can be removed on the shaft and this allows to be shortened but I have not idea.
    If anyone can recommend a set of shorter shafts from another VAG car then that would be great otherwise it's a case of cutting them down, using a lathe, welding and sleeving.
    Not much room for 8's using this setup. What did you do Al?
    I have a G60 setup on the front of mine which is essentially the same as the TDI setup, and I have only used 6" rims on the front.
    Your problem is compounded by how low you want to run as you are moving away from manufacturer specs.
    You going to have to have a measure up and research shaft lengths from other models like polos etc to see if you can find something similar
    May 2016
    Southend
    78
    Yeah that 2" makes a massive difference with the wheels.
    I've been trying to find lengths of various shafts so will probably take these off and then cut them down the same size as the difference between TDI and VR6 wishbones.
    This should allow slight camber adjustment.
    What a headache!
    Thanks for input
    May 2016
    Southend
    78
    Sorted it with mk2 gti 100mm flange driveshafts.
    For anyone looking for similar solution. The 100mm mk2 gti and corado 16v and G60 short shafts are about 25mm shorter than the TDI shafts and lupo gti even more so.
    There is a bare driveshaft lengths thread on the internet.
    Golf 1 / Scirocco 1 & 2
    084 gearbox with 90mm inner CVs
    Short shaft: ???mm
    Long shaft: ???mm
    020 gearbox with 90mm inner CVs
    Short shaft: 445.5mm
    Long shaft: 658mm
    (lengths TBC - both believed 6 - 8 mm longer than '100mm shafts', see below)
    Scirocco 2 / Golf Cabrio
    020 gearbox with 100mm inner CVs
    Short shaft: 433mm, 421mm circlip centreline to centreline
    Long shaft: 650mm
    Golf 2 / Mk2 Ibiza / Mk3 Ibiza
    085 gearbox with 90mm inner CVs
    Short shaft: ???mm
    Long shaft: ???mm
    Short shaft: 443mm, 430mm circlip centreline to centreline
    Long shaft: 677.2mm, 663mm circlip centreline to centreline
    020 / 02A gearbox with 100mm inner CVs
    Short shaft: 432mm (confirmed twice), 419/421mm circlip centreline to centreline
    Long shaft: 681 666mm, 654mm circlip centreline to centreline
    Golf 2 Rallye (4 stud)
    Front short shaft: 432/3mm, 420/1mm circlip centreline to centreline
    Front long shaft: 501mm
    Rear shaft (left): 544mmmm, 530mm circlip centreline to centreline
    Rear shaft (right): 404mmmm, 390mm circlip centreline to centreline
    Corrado
    16V / G60 (4 stud)
    Short shaft: 432mm, 421mm circlip centreline to centreline
    Long shaft: 666mm, 654mm circlip centreline to centreline
    VR6 (5 stud)
    Short shaft: 448mm
    Long shaft: 666 682mm, 667mm circlip centreline to centreline
    Golf 3
    non-GTI (4 stud, 085 gearbox)
    Short shaft: ???mm
    Long shaft: ???mm
    non-GTI (4 stud 020-hybrid gearbox, with 90mm inner CVs)
    Short shaft: ???mm
    Long shaft: ???mm
    GTI / VR6 (5 stud, 020 gearbox & 100mm CVs or 02A gearbox)
    Short shaft: 447/450mm, 435mm circlip centreline to centreline +/- 1mm
    Long shaft: 682mm, 667mm circlip centreline to centreline +/- 3mm
    Passat
    4-stud (~88 - 96)
    Short shaft: 456mm. Measured at 453mm - CE 14.7.11, 441mm circlip centreline to centreline
    Long shaft: 688mm. Measured at 687mm - CE 14.7.11, 675mm circlip centreline to centreline
    VR6, 5-stud (early to mid-90s)
    Short shaft: 456mm
    Long shaft: 688mm
    Golf Mk4
    2 wheel drive (5-stud),
    02K (020-hybrid) gearbox, with 90mm inner CVs
    Short shaft: 460mm, 445mm between the circlip grooves
    Long shaft: ??mm
    2 wheel drive (5-stud), 02A/J gearbox
    Short shaft: ??mm
    Long shaft: ??mm
    2 wheel drive (5-stud), 02M gearbox
    Short shaft: ??mm
    Long shaft: ??mm
    4 wheel drive (5-stud), 02M gearbox
    Front short shaft: ??mm
    Front long shaft: ??mm
    Rear shaft (left): ??mm
    Rear shaft (right): ??mm
    Lupo GTI
    Short shaft: 430.5mm
    Long shaft: 656mm
