Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 81 to 100 of 102
Thread: 9K 1.9 TDi daily project of sorts
  1. #81
    Jun 2016
    Sweden
    121
    The caddy has been taken off the road now, currently have it at work, but will move it to my dads place soon, before they start complaining at work at least haha. Hope to be able to start working on it for real soon.
    Washed her a bit on thursday
    And looked over my new daily beater i just bought, 99 ibiza 1.6, fresh tax and MOT, will use it untill the spring, then break it and use all useful bits for the caddy
  2. #82
    Jun 2016
    Sweden
    121
    Some stuff came in, think these will go well with the color im going for
  3. #83
    527
    Nice, I just changed to clear indicators and smoked side repeaters .looks quite fresh with the Ibiza GTi headlights
  4. #84
    Jun 2016
    Sweden
    121
    Nice! I'm going for Mexican Derby headlights if i can get ahold of a set at all haha
  5. #85
    Jun 2016
    Sweden
    121
    TT filler cap conversion in the works, no turning back now :P
    the hole has been cut up and mock up has started
  6. #86
    Jun 2016
    Sweden
    121
    VAG inox rustprotection paint applied
    Had to cut out a little bit of the flange on the bucket so it could be shaped after the body properly
    Its welded in now, but i forgot to take any pictures of that. I have a lot of warped metal to sort out now, wich will be "fun" :P
  7. #87
    Jun 2016
    Sweden
    121
    The fliller cap will be painted black metallic, with gold plated bolts. so it matches my BBS RM wheels i'm putting on the car. They have black metallic centers, gold plated bolts, and gold plated conical centercap "nuts"
    Will get red/gold BBS emblems for them aswell
  8. #88
    Jun 2016
    Sweden
    121
    The wheels when they were freshly restored a few years back, they are still in pretty good condition as i havent driven much on them. But they could do with a nice clean and polish.
    Getting this type of emblems for them
  9. #89
    Jun 2016
    Sweden
    121
    TT cap conversion halfway there, need to grind all the welds, straighten out all the warping as good as i can, and then its time for a coat of epoxy, the filler work will be "fun".. :P
  10. #90
    3,710
    Quote Originally Posted by snuffegull View Post
    Not a simple job is it. It didn’t help when I did mine I found that the rear quarter was full of filler already.
  11. #91
    Jun 2016
    Sweden
    121
    I bet that sucked. I have done it once before on a mk2 golf, that was easier than this however.
    Todays progress
    Started taking the left rear door apart, found some nasty rust in the bottom seam, might have to write this one off.
    Its nice overall though, Will have a look if i can find a fresh one.
    Minor rust around the plate lights, but an easy fix
    This however isnt too fun, nothing has gone trough to the outside though, so could maybe be worth a try to save it
  12. #92
    These 9K's do like to rust in the rear end!
    Excellent work so far
  13. #93
    Jun 2016
    Sweden
    121
    That sure seems to be the case :P
    Thank you
  14. #94
    Jun 2016
    Sweden
    121
    For todays sesh i could not get the van into the shop as it was blocked in by a 2k with smashed up suspension, that the towing guys had dropped off with zero fucks given as usual..
    So i decided take the right side rear door off and work on that.
    First i stripped the door down completely, then i started dealing with the very minor rust it had, went at it with just about every tool we have in the arsenal to really get every single pore of it out, including a spot sandblaster and a really agressive rotary steel brush made specifically for rust and seam sealer removal
    Then i i went at it with 180 grit paper and sanded it down to bare metal, and then i straightened out a couple of small dents, then i went over the whole thing again, this time with 240 grit paper.
    Epoxy time in the small paint booth
    Still need to sort out the inside, and redo a bit of the seam sealer in the hinge cutout areas, some body filler work, and more primer.
    Next thursday i hope the van wont be blocked by some busted up car so i can get it in :P
  15. #95
    Jun 2016
    Sweden
    121
    We get off work at 14.30 on fridays, but the shop closes later, so decided to stay for an hour and fiddle with the door some more.
    Sanded down with 240 grit, and a thin coat of 3M fine bodyfiller applied where needed
    Filler sanded with 180 and then 240 grit, most of it is more or less good now. Next step is a skim coat of Upol Dolphin glaze over much of the door
  16. #96
    Aug 2016
    fife
    56
    Nice work!
  17. #97
    3,710
    Nice work as always.
  18. #98
    Jun 2016
    Sweden
    121
    Thanks guys
    Next week i hope to get some decent progress done for the right side of the body. Since i have the door off anyways, and the majority of the work on this side is done.
    Still some welding to do in the door sill area, a little bit under the rocker, and in the upper door hinge area. Also need to weld up some holes in the wheel housing from a previous shelf installation, and i need to fab up a new filler neck bracket as that thing is toast. Also want to take the front fender off soon so i can strip the whole rocker down to bare metal.
    I might finally have found a guy willing to get me some mexican headlights also, so thats exiting
  19. #99
    Dec 2017
    Russia
    1
    Cool Caddy =) Good job
  20. #100
    Jun 2016
    Sweden
    121
    Thank you
    Yesterdays progress
    Tore her down a bit more
    Cut out some rust
    Started to dig into some stuff in the pinch, and i'm actually concidering to change this sill now. They are cheap enough, and it will save me time, and the quality of the repair would be better. Would cut down a Ibiza/cordoba/polo classic 4 door sill and join it in the factory seam probably, and cannibalize the left over rear peice to patch up the rust further back.
    Some more work done to the rear door
    Really need to clean and polish my wheels
    How she currently sits untill next sesh
