Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 121 to 140 of 156
Thread: Time to finally upgrade my Mk1 Caddy
  1. #121
    348
    i was looking at how you fitted yours before i cut mine lol.
    not a great deal of information about but i kinda pieced bits together and adapted some ideas till I got what I was happy with. still along way from testing it though lol as we still have half of the caddy to weld up.
    Ant what size fuse are you running on your eps?
  2. #122
    348
    Had a good day on the caddy today.
    kinda forgot i was putting a hydraulic clutch on so had to adapt the steering coloum again.
    removed the lower collar that I had put on and made one that bolted around the body using one of the original brackets from the eps
    then once we had completed that we had to modify one of Al's hydro brackets
    thanks to Al sending me a long cotter pin I haven't had to modify the pedal at all so I will now have an eps coloum and hydralic clutch all mounted on the original coloum fixings
    I have some cleaning up to do then it will look oem
  3. #123
    Sweet!
    Looks like it was pretty straight forwards in the end!?
  4. #124
    348
    mounting the hydro was easy, followed your insruction to the letter.
    making the new colloum fit was time consuming.
    just need to clean in side of the new coloum then mount it all on monday.
    took my time as I wanted it to all bolt together and mount on the original brackets etc. look oem and it will be solid the way that I have done it.
    bought that v5 box and will pick it up tmro.
    did you manage to make up some mk4 pedal brackets?
  5. #125
    348
    another good night on the old girl tonight.
    eps and hdyro all finished bar powder coating
    and my mate finished the drivers side repairs
    a few patches still to do on the drivers side which i have made, just need to cut in and weld up.
    Wednesday evening were starting on the passingers side and hopefully my bits for the bulkhead turn up tmro so I can finish off the engine bay.
  6. #126
    348
    quick update,
    passinger floor pans removed
    and I've modified the servo to fit the mk1 linkage. now upgrading the brake rod system.
  7. #127
    15,147
    Eps fits in there perfectly. I bought a motor years ago to do mine, maybe I'll get round to it eventually
  8. #128
    15,147
    I'd recommend ditching the silly rod system and going direct. Though u'd expect to loose loads of space, it tucks in behind the engine well
  9. #129
    348
    don't you have to modify the bulkhead etc alot to make it work?
  10. #130
    15,147
    Yes you would need to modify it a bit, but seeing as you are chopping up everything, it might be worth considering
  11. #131
    348
    not quite chopping lol presion engineering
    as that part of the bulkhead is rotten it would make sense.
    did you move yours 13?
  12. #132
    15,147
    I did mine though it wasn't that neat
    Al did his on the vr6 and reg on his mk1 golf.
    I'll try and find u a pic
  13. #133
    348
    I have done some reserch now and found regs pics so know where i need to be lol.
    so out comes the coloumn again lol. cheers 13 I probably would have carried on using the old system but can see its not too difficult to swap over
  14. #134
  15. #135
    348
    cheers Al, I've taken screenshots of yours lol, I think Regs way is the way I'll be going
  16. #136
    Aug 2009
    East Sussex
    288
    Great work!
  17. #137
    348
    Quote Originally Posted by Old_School_Cool View Post
    Great work!
    Cheers mate, this certainly has been eye opening lol.
  18. #138
    Aug 2009
    East Sussex
    288
    i just wish i had access to a workshop like that! haha
  19. #139
    348
    I wouldn't be doing this if I wasn't lucky enough to have access to all the tooling etc and of course the 4 post lift lol
  20. #140
    348
    ok so after 13's idea I started to install the servo pedal side.
    still alittle more metal to come off of the inner wing then I can start replacing the metal and making it look better than it does now lol
