Page 13 of 13 FirstFirst ... 3 11 12 13
Results 241 to 247 of 247
Thread: Mike's MK1 Caddy Sport 24v VR6
  1. #241
    5,006
    Looks good, we’ll done! There’s some good metal work on here lately.
  2. #242
  3. #243
    Ok so I managed to get some time on the caddy last week, test fitted the bags
    then pulled the axle again to change the end plates as I wanted to make them look cleaner and now there tapped as well.
    then we cut the axle down 26mm and put on the new end plates and the start of the panard bracket.
    hopefully get it back on the car tonight and mock up the panard bar etc. so far so good.
  4. #244
    grimsby
    132
    Looking good dude ��
  5. #245
  6. #246
    had a good night on the caddy last night, mocked up the panard rod and had a little play sorry testing the bags etc, can't get it all the way down yet as we need to roll the arches to clear the rims. once we have done that I can then put in the stops which we've integrated into the panard mounts, should sit an inch lower than it is now.
    slowly getting there.
  7. #247
    Have struggled to get time on the old girl of late,
    modified the towers where the 4 link attach to allow full movement
    Just need to weld the 5th link to the chassis then the suspension is sorted. Have now managed to measure the full movement and thankfully Koni Reds are perfect for what I need so just need to pick some up from Al.
    Also had some brackets cut for my air tank but f*&k up my measurements and have had to re-order them.
    have also been making up all the mounts for the fuel lines, air lines etc. Will take some pictures tonight of these.
