Page 22 of 22 FirstFirst ... 12 20 21 22
Results 421 to 437 of 437
Thread: Jango's 2nd attempt......
  1. #421
    Romsey
    575
    Shaun, I have a pretty quite day tomorrow, if you text to remind me I will measure what you need
    Thanks Al. I'll drop you a line tomorrow. That's a very kind offer.
  2. #422
    Romsey
    575
    I've now attached most of the bits under the bed...
    It was so nice welding new metal to new metal. Some of the welds looked like some that you guys produce.
    But does anyone know exactly where this little fella goes?...
  3. #423
    200
    that little fella goes right at the back on the last crossmember with a plate below it, heres a picture, very bottom left corner u can just about see it.
    Great work jango this is turning it really well, welding new metal to new is a great feeling, isnt it.
  4. #424
    Romsey
    575
    Bingo! Thanks Nick Nack. And yes, new metal feels sublime. Although I've just found more rot inside the other sill (repaired badly and rotten again). It was well disguised. And I think I might have to replace most of the drivers floor too.
  5. #425
    200
    Quote Originally Posted by Jango View Post
    if you're gonna do it, may aswell do it properly! i regret not putting new floor pans in, my reason was because they were already new, but i should've just done it for peace of mind.
    Yours will be nice and rot free for years to come! just make sure to epoxy the whole thing!
  6. #426
    Romsey
    575
    Today has been enjoyable. I've chopped out more rust and prepared some new bits to go in.
    Here's an aerial view of my efforts. I'm looking forward to welding in my new panels tomorrow.
    I've had to cover my new inner panels with weld through primer as it's all I have and I thought it better than bare metal. Once it's all built I will give it all a high colonic with that waxy stuff I've seen a few of you pros use.
  7. #427
    I suspect after all this..... you will be considerably more "pro" and caddy knowledgeable with actual experience than most of us
  8. #428
    Romsey
    575
    No chance. I will always be a novice. I'm middle aged and fanny about on the weekends. Many if the good folk on here have been playing with this sort of stuff for decades and some professionally, so I know my place for sure.
    I very happy occupying the bottom rung, all visitors welcome.
  9. #429
    Romsey
    575
    I finished the 'innards ' and I'm going to run a new outer sill down the side as the old one has holes.
    As you can see, I haven't welded the part near the inner arch. I figured the inner was coming out so I'd wait and weld it to the new bit once I get to it.
  10. #430
    Romsey
    575
    After a planned break from caddy land I've already gotten confused. Here's what I've done, followed by images of what I don't know....
    I've begun to put both sill sections in. It all marries up with the swage line.
    The image below shows one dilemma. Does the arch go on top, under or does it butt up against the sill?
    This image below shows a potential nightmare. Everything lines up and I've screwed it in place before I weld it, but look at the bottom edge!!!! Its landing unspeakably high. Do any of you chaps know where I've gone wrong as I have lined up the swage line but it still falls short.
  11. #431
    4,486
    You don’t want to overlap your joints at all, especially on the wheel arch. Also, you don’t need to replace all tht are around the arch so cut away some of the excess and only replace what you need to. Looks real close to the filler cap too and there’s no point fucking about going that far out. Regarding the bit at the bottom, again don’t overlap, just but the pieces up together and then pull them apart just a smidge so there’s room for the weld to get right in there
  12. #432
    looking at your previous pics it looks like the inner part was deeper than needed.
    Compare to the opposite side
  13. #433
    Romsey
    575
    Again, thanks Al. All duly noted. I've taken on board what you have suggested. Below is my interpretation of your wisdom.
    As you can see, it's all screwed in place and awaiting to be welded in.
  14. #434
    Romsey
    575
    Quote Originally Posted by worthingcaddy View Post
    Cheers Ant. Most of its cut and secured. I've just to butt up the sill part and weld it all in.
  15. #435
    Romsey
    575
    So, this is what my best effort looks like. Perfection is far from here but it feels ok. Any tips are always welcome.
  16. #436
    5,007
    Yes, try grinding those welds down
  17. #437
    Romsey
    575
    Will do. I was afraid of taking too much off. Cheers dude.
