Page 2 of 24 FirstFirst 1 2 3 4 12 ... LastLast
Results 21 to 40 of 471
Thread: Jango's 2nd attempt......
    Romsey
    593
    Thanks guys. The rad fan switch is looking corroded and disconnected. I guess there is a damaged wire somewhere. I'll get a switch and go from there.
    Romsey
    593
    So I've been reading Monkeys fuse box thread and despite its clarity, I'm confused. Perhaps a grown up can help me.
    I understand that I have a series 1 fuse box. The details I found are for the CE1 fuse box, which is different.
    Am I right in assuming the wiring colours are the same across all caddy's ,i.e. Rear fog = grey wire/yellow stripe?
    Where would I find a guide to which fuse is which on a series 1 fuse box?
    This is my fuse box.
    You Caddy never left the factory with that fusebox! Why the hell someone would do that is beyond me?
    Romsey
    593
    My good fortune with caddys is consistent if nothing else.
    My caddy began life as a 1.6 petrol. It has the engine swapped to a 1.6 d when it was 4 years old. Perhaps it came from the Passat that was the donor? It is my understanding that the donor car was the same age as the caddy......
    Do I persevere finding the wiring diagram for this fuse box or get a CE1 fuse box and make it as it is meant to be?
    Romsey
    593
    Would any of you electrically minded chaps be able to point me in the right direction?
    Should I change my fuse box or unjuggle the one I have now?
    lol thats strange!
    does everything work? why change it?
    I'm sure my Bentley manual said those were possible up to 1986
    Romsey
    593
    lol thats strange!
    There is a manual switch on the dash board for the rad fan and for the rear fog. I don't fancy constantly being vigilant as to when to switch the rad fan on. I know I'll forget one day.
    And the fog light switch gets flipped ever time I wind the window up! There are a few wires fitted to keep her going but they are all red.
    I'm thinking that I should fit a CE1 fuse box and an engine loom so that I can converse with those who know my system if there is an issue and that it will become a part of the car that should be reliable as its new.
    Having said all that I have no idea how much a fuse box and loom will cost....
    And thanks for the diagram.
    A loom and fuse box shouldn't cost u much- ask someone who's breaking one. I dunno how the connectors differ, you can have the ce1 fuse box I have here for £15 if u want it, was just about to dip it in copper cleaner and stick it on eBay, but you might get everything including a fuse box cheapest
    Romsey
    593
    Thanks. I'll give it some more thought.
    No problem
    Romsey
    593
    I fell into a bucket of wires in my store room and climbed out holding this..
    So I began to think about getting a loom made. However I need some guidance as the connectors that go into my old fuse box for the dash and rear electrics don't seem to match the holes on the CE1 fuse box.
    Should I try and source an engine loom that fits my old fuse box? I'm a little puzzled...
    Romsey
    593
    I don't suppose anyone with electrical experience could take a look at my previous post. I'd really appreciate some informed perspective... Cheers.
    They stopped using that style of fusebox in the early 80's
    why the hell someone would retro fit that is beyond me. Especially as the diesel is about 8 wires
    all fixable. See what looms you have, I can convert them back to ce1 and make it all work nicely
    cant help thinking the easiest option is to buy a complete 1.6d loom and replace every thing - though i don't know what the switches are like. seems a safer bet that cutting and splicing everything,
    you don't have to splice anything. The pins inside the housings are interchangeable between CE1 and series1. So as long as they are intact i can swap them from one multipin to another
    however if they have been butchered to get the series1 fusebox in there then yes, buy another.
    Romsey
    593
    Could someone tell me which engine this is please?
    I'm in the process of getting my looms redone and I though it best to get some new temp sensors. Below is a pic of the ones I wish to replace hilighted with post it notes. Also where would folks recommend I get them from? Thanks in advance.
    Take a look at the engine number, the first 2 or 3 letters will be the code
    Romsey
    593
    Thanks Al.
    But as you know by now, my luck in situations as simple as these is still poor. My log book says CR and my engine looks hand stamped by a centre punch to form the letters JF!
    I guess I'll play pot luck with the heritage folks unless there's a better option. I've looked on the retrofication site first, of course.
    Romsey
    593
    Progress happened today!!!
    Got all my looms personally delivered and I helped with the installation (I made the tea). Naturally, it turned out that my engine was very old stock and not known for propelling a caddy.
    Massive, heart felt and much appreciation goes to Dub Monkey. Such a nice and genuine chap.
    I would have had no chance of getting my truck wired correctly if I didn't get his help. Cheers dude.
    Quote Originally Posted by Jango View Post
    Should have said, I was in Wellow this morning
    Shaun what happened to your old shell?
