Page 11 of 22 FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 201 to 220 of 437
Thread: Jango's 2nd attempt......
  1. #201
    Romsey
    575
    Here you go https://rover.ebay.com/rover/0/0/0?m...2F152781988341
    I rub them off a bit before use
    Bingo! Thanks amigo!
  2. #202
    Quote Originally Posted by Jango View Post
    Quick update.
    Not done a huge amount. I've got all the left sill fitted. My welding is solid but ugly and I've yet to learn about grinding.
    What you will learn is.....
    Make your welds flat, coz grinding is noisy, dirty, boring, fills your lungs, shed and white Up! Parked outside full of shitting rusty dust.
  3. #203
    Romsey
    575
    Have you been spying on me?
  4. #204
    Romsey
    575
    So this is my first swing with these flappy discs. I can see the errors of my ways. So much more to learn. Big thanks to Elroy, tontoe and 13 for taking the time to try and teach this old dog new tricks.
  5. #205
    I usually use a grinding disc to loose the hump. Flap discs to pricey to use all the time
  6. #206
    Don't listen to tight arse!!! Always use flap discs!! I always rub the new ones down a bit on a bit of scrap steel.keep the really used ones for final finishing! Grinding discs are good for nothing! You only need stainless slitting discs and used flap discs !
  7. #207
    5,007
    The noise made from grinding discs is enough reason to use flaps.
  8. #208
    Romsey
    575
    Thanks for the clarification chaps. I'll strike a balance between my ears and my wallet.
  9. #209
    If you were any good at welding, you wouldn't need them
  10. #210
    Romsey
    575
    Nobody's welding is as bad as mine is right now.
  11. #211
    Surrey
    2,725
    i dunno, i bet i could give you a run for your money
  12. #212
    Or monkey
  13. #213
    Romsey
    575
    I had a mate pop by last night who has done all this bodywork and welding malarkey his whole life. I got him to demo lots of different skills on my truck. It was only 45 mins but the little bits he showed me would have taken me weeks to do a shitter job of.
    What an eye opener.
    Now I can't blame my tools any more
  14. #214
    Surrey
    2,725
    What an eye opener.
    Can you not get him to come and do another demo next week and do abit more for you?
  15. #215
    Romsey
    575
    Quote Originally Posted by blenki View Post
    If only. He works or a posh car company and he's off to Singapore to do whatever it is he does.
    However, I learned that my welding wire needs to be 0.8mm not 0.6mm, which may explain my burning through issues. He also cleaned up some of my welds which looked far better.
    I'm really happy to go back over my old work and make it all better. And the lighter evenings will help also as my garage lighting is terrible.
  16. #216
    grimsby
    132
    Thats what i run 0.8 wire for 20 gauge (.81mm) sheet steel, anything body panel related, jacking points etc, thicker steel like the rear leaf spring turrets and such i put 1mm wire in but the majority of it needs 0.8 ��
  17. #217
    Romsey
    575
    Quote Originally Posted by lumberjack23 View Post
    That's great to hear. I'm on the right track and running out of excuses for producing such slow and poor work.
  18. #218
    Have you tried a work light? I used to use those halogen ones on a pole but I bet a modern led one would be crackin
  19. #219
    Romsey
    575
    I've not tried halogen lights, but I have a couple of high power LED lamps. They seem to cause more shadow and also dazzle from the freshly ground metal.
    However, I am very fortunate as my employer, who have given me my workshop for free, have sent an electrician round yesterday and have agreed to fit some new lighting. The good news is that the electrician did the lights at a main dealers the other day and knows more about what I need than I do. I feel very lucky indeed!!!!
  20. #220
    grimsby
    132
    I fitted led batton type lighting above my work station and get so much glare down the back of my mask now, drives me crazy, gonna have to move it!
