Page 27 of 31 FirstFirst ... 17 25 26 27 28 29 ... LastLast
Results 521 to 540 of 612
Thread: My first project
  1. #521
    1,490
    London Cartel Show / Action in August still very much the goal, although with a bit of luck I'll be able to get it MOTed when I finish uni in June *He says optimistically*
  2. #522
    Jul 2010
    Stanley Durham
    3,658
    Paint job looks nice, it will look so much better out side
  3. #523
    1,490
    Any slimline fan recommendations? or eBay special to the rescue?
  4. #524
    4,825
    Woohoo!
    Someone’s posted
  5. #525
    1,490
    Bit of a forum dry spot!
  6. #526
    1,559
    How slim does it need to be fuss
  7. #527
    1,490
    Hmmm isn't that a question... I assumed all slimline fans would be much of a muchness... Suppose I'd better actually get my caddy back and go some measurements
  8. #528
    1,490
    I'm going to chop through where the red marks are, and attach a slim fan to what remains hopefully to make the whole shroud much thinner but still retain the heat separation properties
  9. #529
    Nov 2008
    Surrey
    2,714
    Will you not need a bigger rad for the PD setup?
    Just fit two slimline fans and do away with the shroud
  10. #530
    May 2008
    lewes east sussex
    1,685
    Dont know about the fan but Happy birthday anyways!
  11. #531
    1,559
    Reson I ask is a have a mk4 tdi one if you want it
  12. #532
    1,490
    Quote Originally Posted by blenki View Post
    Having spoken to those already running this setup I should be fine with the stock radiator to start with, obviously if I intend to rag it all the time It'll show on the gauge and I'll know I need to invest in something bigger.
    If I recall Tagg senior drove all the way to Austria with a "Scene" tiny 1.3 radiator in his PD just fine, so I reckon I'll manage fine with a significantly larger 1.6D one
  13. #533
    1,490
    Quote Originally Posted by tontoe View Post
    Ah I also have the donor's mk4 radiator fans lying around at home, I'll investigate that. Got a feeling it's got a fat motor on it though....
    Thanks for the wishes DMF!
  14. #534
    1,559
    Quote Originally Posted by fuus View Post
    Worth a look! Enjoy your birthday!!
  15. #535
    Nov 2008
    Surrey
    2,714
    I wouldn't say fine. He's upgraded to a larger rad
  16. #536
    1,490
    You do make a point. I'm just going to get it on the road and worry about a bigger rad later
  17. #537
    Aug 2011
    horncastle
    283
    Paint looks spot on.
    Did you get them bits sent?
  18. #538
    1,490
    Stock Radiator for a PD150 - 399 x 24 x 647 = 6,195,672
    Stock 1.6D Radiator - 570 or 525(?) x 325 x 25 = 4,265,525 min or 4,631,250 max
    Quite a big hit on volume...
    for comparison VR6 Corrado Radiator - 630 x 322 x 34 mm = 6,897,240
    Would I regret buying a cheap radiator like this? https://www.ebay.co.uk/itm/VW-Corrad...QAAOSwoR9aBIBC
    also what hoses are going to stretch all the way over there?! lol
  19. #539
    572
    Rufus although untested I have just bought a mk2 passat rad which has a core size of 700x320x34 assuming all your pipes are on the left hand side
  20. #540
    1,490
    What was the damage Mike? How does it fit in the Caddy? Does it line up with the widest pre cut radiator mount holes? I'm interested in seeing how it works out for you!
