Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 21 to 40 of 118
Thread: FOR SALE 200hp + TDI Maxi Life Project
    ROMFORD, ESSEX
    7,018
    They were, although like anything retro they are sort after now. The Chamois was the posh Hillman Imp, mine cost me £60, imps were worth about £30 lol
    I remember my brothers and sisters Hillman imps... Wow what fun we had messing around in them down chertsey by the river in the grass car parks.... Rallying lol....
    One word I will mention "doughnuts"
    Quote Originally Posted by B1G VR View Post
    And I can remember it braking down.
    Accelerator cable snapped It broke down in St Albans as well, and when dad took me back to pick it up, I couldnt remember where it was we drove around the town for about an hour lol dad wasnt amused
    The "Life" was delivered today, and to my amazement its still runs on 3 cylinders , and this is with a gaping hole in the block, no oil or water lol
    Oct 2014
    WIRRAL
    39
    Hi Al & looks like a VR6 is going then. ????
    Quote Originally Posted by NEIL4022 View Post
    Not this time
    Will be getting a PD 150 engine and injectors with a hybrid PD170 turbo and mapped to around 200hp (or as much as I can get on a smokeless tune).
    Oct 2014
    WIRRAL
    39
    Hey that sounds very interesting and keep the thread going and lets all see what you get up to in your workshop.
    Good luck Neil 4022.
    Oct 2014
    WIRRAL
    39
    Nice home workshop as well with very posh cladding. That would be a first time home near me £99.999 & 99 down & move in the next day.
    Thank god for wimpy homes. Lol
    Right
    Got the PD150 engine with a missfire into the workshop ready to strip and inspect!
    I did a compression test whilst it was in the Golf which turned out to be inconclusive
    The air filter was muddy, damp & mouldy, so I suspect water ingress which means there is a good chance of hydraulic lock and a bent rod or two!
    Before removing the belt I just wanted to check the cam timing as the belt looked a bit ropey and had been catching on a bent cover But the previous dickhead who had done the belt had chewed up the Allen bolts, so I had to drill out 3 of the 4 (nothing winds me up more than undoing some other cunts lashup).
    Turns out the timing is spot on so can eliminate that one
    Moving on to the injector loom. When I removed the loom from the injectors No.4 cylinder broke apart! Im not sure if I was a bit heavy handed, but these looms are very brittle anyway and should be changed as a matter of course. But more than that, VCDS showed a missfire on cylinder No.4!
    Things were going smoothly, and then when I was ready to remove the head I run out of tool talent I could not find my 12mm long spline anywhere, so that put a halt to this afternoons work
    More updates when I either find or purchase another tool. Bollox!
    Ok, tool problem solved
    Removed the head to reveal:
    Spot the deck heights! No.4 cylinder nearest which is approx 2-3mm down on the others!
    That will be a bent conrod as suspected then
    can you use one from the other engine or is that just dangerous??
    15,641
    Lol
    good diagnostic work there Al - I didn't know how to look for con rods before
    Aug 2014
    Hampshire, England
    1,103
    With that agu im sure you'd of figured it out in no time
    Quote Originally Posted by DubMonkey View Post
    ASZ & ARL have bigger cajonas (journals), plus BLS conrods are made from chocolate
    They are normally found between the pistons and the crankshaft
    No "Doritos" in a proper engines
    Scotland
    13,789
    You remind me of Al but with more of a sense of humour.....
    15,641
    Yep - Very good Al
    Yep - Very good Al
    I couldnt tell if you were being sarcastic or if you were blabbering scottish again
    Contents of an engine under tray, can you identify the content!?
    Engine Removed today and jet washed to remove the oil shower!
    Last week I bought another donor car as I have decided to use the above engine for something else later on
    Removed the Bora engine this afternoon, so will start the mods on the block/crank sensor later in the week
    I will be also using the 6 speed gearbox from this in the Caddy
    Received the new GT1749VC Hybrid turbo from www.xman750.co.uk today
    This turbo basically uses the PD140 8v Hot Side/Manifold with the PD170 16v innards and once mapped with the PD130/150 injectors we should see the best part of 200hp which will be plenty for a daily driver
