Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Results 41 to 60 of 211
Thread: mk1 sport to v6 24v
    Sep 2005
    oxfordshire
    2,557
    Right come down to do a bit and I've lost/misplace said little olive that I was holding in pic where can I buy the fitting or Al can you send me another please ??
    Sep 2005
    oxfordshire
    2,557
    As I'm buying a second had flywheel are they stretch bolts used on the vr6 flywheel to secure or can I fed used ones think it's 10 needed if so any body got any or a flywheel before I buy of the bay?
    surfing the forum when I should be writing reports..... (Aylesbury or Lincoln)
    1,331
    If it's the same as a 1.9 TDi, then yes, the flywheel bolts a stretch jobs. I got some from my local main stealer for about 3 quid a pop
    Sep 2005
    oxfordshire
    2,557
    For the likes of al and slim if going turbo what turbos are suitable ?what exhaust Mani can be used with what turbo?
    Any links to management side of things and any other related parts needed advise you can give to either convince me or put me off
    I'm seriously considering it now ... As I may only end up doing it later ..! Bare in mind it's the 24v there seams to be kits for the 4 motion ... But obviously room is an issue in mk1
    Sep 2005
    oxfordshire
    2,557
    Ŵhat intercooler Are people using?
    Sep 2005
    oxfordshire
    2,557
    I see that al and slim have relocated the servo is this a must? Also rain tray is staying..!
    Quote Originally Posted by MadDub View Post
    Dont turbo it, I would fit some Schrick cams and go over to throttle bodies instead.
    Many of the "middle of the road" stand alone ECU's are much of a muchness, so find a good tuner that is not the other side of the country, and then ask them what ecu they prefer/are familiar with.
    Sep 2005
    oxfordshire
    2,557
    Why no turbo al?
    Sep 2005
    oxfordshire
    2,557
    What's the deal with chargers??
    Why no turbo al?
    You have 200hp already, cams and bodies will see you to 250hp, would sound phenomenal and be very drivable and relatively simple
    Much less heat generated than turboing and packaging is very hard in the MK1 engine bay.
    But if you must, you would ideally need an inlet manifold as well as the exhaust, as the plastic intake will explode with any reasonable boost. There is no room for an intercooler unless you are prepared to chop out the front panel and crossmember and then put strength back into it. Battery would really need to be relocated. Servo position is fine. There are many suitable turbos depending on your goals but expect to pay £1200-£1500 for one. you will also need to lower the compression ratio with a head spacer.
    You could use the OEM management for turbo'ing, and I know someone local who can do that.
    PS. Are you still breaking that 2K ???
    Also;
    Say you went the cams and TB route. You could find yourself an R32 motor later on and have 300+ aspirated!
    ^^^^im tempted with this myself^^^^
    Sep 2005
    oxfordshire
    2,557
    There is athred on the red vento r32 on boddies
    Sep 2005
    oxfordshire
    2,557
    Sorry caddy 2ks gone I raped the bits and chopped sill off and my mate baught it to build back up ..
    Jun 2007
    Kendal,Cumbria
    1,646
    Also;
    Oooooh yeah I like the sound of this! The engine noise would be immense.
    Sep 2005
    oxfordshire
    2,557
    Anybody got a mk3 rear gesrbox mount??
    Sep 2005
    oxfordshire
    2,557
    Just needing the bush bit?
    Sep 2005
    oxfordshire
    2,557
    Just been reading up on Worthing's caddy about the down pipe and wondered what size tube to use ...2.5"??
    Mate, these are only about £10 new from GSF etc
    the 24v is different to the 12v, have you not got any of the original downpipe?
    Sep 2005
    oxfordshire
    2,557
    Nope Dave said it had split I've just got the cast mani..!
