Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 21 to 40 of 211
Thread: mk1 sport to v6 24v
    MK2 Golf cable has to be from the 1.3
    Only the early Corrados had cables and converter and are hard to find
    Sep 2005
    oxfordshire
    2,557
    cool.. im guessing that all speedo drives of the golf mk2 /corrado of this type would bee the same though..
    Sep 2005
    oxfordshire
    2,557
    firstly mods can you move this to build threads as I didn't realize its in wrong section cheers...
    well work has started
    engine out and all sport loom removed
    had to mock up the brakes to measure the hoses for the hel ones im getting made up...
    Sep 2005
    oxfordshire
    2,557
    Hope there up to the job!!
    Sep 2005
    oxfordshire
    2,557
    big thanks to monkey's courier services ...
    these have just arrived
    ready for colour coding and new bolts
    Sep 2005
    oxfordshire
    2,557
    should have a good sunday on it so shall get the pedal box out for you Al...
    Sep 2005
    oxfordshire
    2,557
    Well rain stopped play today so Finally got pedal box out, swapped brake pedals and installed .. Just need to sort the hoses
    How does the little nipple go do I flair the pipe to fit in or just put over the plastic inner pipe?? If that makes sence?
    Also got mount off in one piece and ground off made a little hole with cold chisel but will be welded up obviously
    Sep 2005
    oxfordshire
    2,557
    Must say I was impressed with the pedal box kit and fittings even supplied me with a new pedal rubber for my old brake pedal to match the already fitted clutch pedal..!
    Al old one is packed and ready to post asap...
    1,892
    Slide your end fitting over the pipe 1st,then ease the sleeve away from the plastic inner just enough to get the collar over the inner plastic,then place the 2nd part over the collar and bring the end fitting down and screw up trapping the outer braid if that makes sense
    Sep 2005
    oxfordshire
    2,557
    Nice one fisherman... Thats basically what I was doing but as the plastic pipe inside the Braid will need flaring / bevelling ..slightly made me doubt my self.. I'd already slid the fitting down the line already
    Sep 2005
    oxfordshire
    2,557
    Sorry just re- read !!
    So I poke that little beveled piece over the the inner plastic pipe as if the pipe could go through it ?? I just thaught as it's beveled it would go inside not over the pipe?
    There's a vid from the fittings manufacturer on youtube that shows how exactly how it's done
    1,892
    Quote Originally Posted by MadDub View Post
    Yes then your last piece goes inside the plastic inner core and when you bring them together and tighten,the bevelled collar will then be tightened down onto the inner with the end fitting tube to tighten against
    If you can find Monkeys link obviously that will explain it more clearly
    make sure the end of the hose is cut clean.
    slide the locking nut up the hose
    Next peel the braid away from the plastic inner a little
    Then push the olive on until its as far as it will go
    then push the fitting in
    And then pull the locking nut back down the hose and tighten to the fitting
    http://www.youtube.com/watch?v=3tjRsbSDA48
    Sep 2005
    oxfordshire
    2,557
    All makes sence thanks..
    Sep 2005
    oxfordshire
    2,557
    Also the mrs sent old unit back yesterday Al..
    cheers mate
    house or workshop?
    Sep 2005
    oxfordshire
    2,557
    Farnham address be with you by Thursday
    West mids
    2,817
    Always liked this caddy, nice to see it getting some love.
