Results 1 to 12 of 12
Thread: which first, primer or filler?
    17,866
    I've got a section of bare steel on the truck, it needs a skim of filler.
    I've always primered then filled, as I'm paranoid about it rusting under the filler.
    I've read that others fill then prime.
    What's the right way to do it?
    3,753
    I fill them prime but never wet and dry filler always use production paper.
    Dec 2010
    Camberley
    1,872
    Quote Originally Posted by mitty85 View Post
    +1
    If the metal is clean before the filler is applied, then sealed with paint, there is no way for the metal to oxidise. Filler also adheres to the metal better than paint and you will get a better feather edge.
    two things scare me, spiders and pump timing.
    17,866
    I'm not sure what the difference is? I thought it was aluminium oxide based or do you mean the process is important i.e. not introducing water?
    process I think.
    the old man always used to go onto bare metal when he had his bodyshop.
    Dec 2010
    Camberley
    1,872
    some fillers are porous, if you sand them wet, the metal behind the filler can start to corrode . Rust can exert 2500lbs per sq inch so it's better to keep it as dry as possible.
    Nov 2009
    bath
    2,135
    thats a +1 from me to!
    15,398
    In my huge experience I can never understand wet sanding - Filler & primer is like a sponge
    17,866
    it's easier/faster and less dusty?
    I also cringe when I get that dry dust on my hands, but that's probably just me being a bit of a mary. I cant deal with chalk and chalk dust either, so 2 years of teacher training was a dumb idea really!
    Aug 2004
    Barnsley, South Yorkshire
    692
    Polyester based fillers are porous, but aluminium based fillers are not porous. Learnt that from practical classics i read today. They doing a body filler test.
    Forest of Dean
    3,322
    this is a chicken or egg question, the answer depends on who you ask,
    for me i find sealing the metal before anything else means i can then wet and dry it, wet sanding will always gives a much smoother finish.
    Rubber dub.
    Why have one caddy when you can have two at twice the price
    17,866
    Indeed hence the title.
    I've always put on the primer first, simple because when I've worked on cars that have been filled with no primer first, they are often rotten behind the filler but then that may just be down to poor prep to begin with.
    Then you have the adhesion problem of filler onto paint...
