Page 2 of 2 FirstFirst 1 2
Results 21 to 36 of 36
Thread: MK1 Suspension FAQ
    West mids
    2,817
    Notching the chassis....
    Is it strictly reserved for the very low, rolling on 13's with 2 inch blocks ? Basically at what point would it be a problem ?
    AJH 20vt 88 CADDY -------- KR 16V 83 JETTA (SOON TO BE AN ACE 2LTR 16V
    wigan
    96
    Stupid question if i fit the flipped axle onto the caddy if ive just flipped it without lowering blocks can i use the same ubolts?! Or would i still need longer ones I understand it would be best practice to get new ones anyway but just wondering
    Sep 2010
    southampton
    1,284
    Quote Originally Posted by pilky1234 View Post
    you can use old ones, but new ones is best!, if you get inch and half blocks with yours i will buy them off you seprate
    Dec 2011
    Doncaster! As requested by pingu!
    2,936
    yeah you can use the standard bolts. remember to get shorter shocks! im yet to buy some saying that!
    wigan
    96
    Yeah i should get my flupped axle back tommorow and i will be getin some lowering blocks and obviosly longer ubolts eventually aswell as shorter shocks but i drive about ten mile a week if that so no rush it was more so i could fit the axle so i can estimate how far i need flare my arches for my 8.5j 0 et banded steels goin on
    Dec 2011
    2,936
    my help but try willtheyfit.com nothing to do with your arches but may give you a visual which you can work to
    Nov 2011
    South Yorks
    48
    Axle flip
    Newbie here and I'm curious to know by how much will it lower the rear of my MK1 caddy if I flip axle without any other lowering devices such as blocks. So to summerise how much does a basic axle flip lower the rear of the car by?
    thanks
    9,717
    around 120mm without any blocks
    Jan 2012
    Oxfordshire
    68
    Sorry don't know if I just missed this but I have just flipped my axle gone to put the wheels back on and they seem really close to the arch as in not central have I done anything wrong or anything I can do to centralise them? Also wondering if they centre a little when let down back on its wheels thanks,
    Apr 2012
    On the down low
    2,107
    Chadders, it's common
    you need to drill the axle to centre it.
    Full detailed info in the "how to" section.
    Jan 2012
    Wakefield
    2,247
    Quote Originally Posted by elevensies View Post
    It's not how you drill the axle it's where the hole in the spring saddle is.
    Look at how these are for example.
    http://www.justcaddys.com/weldon-spr...s-pair-of.html
    Jan 2012
    Oxfordshire
    68
    Where abouts is the how to section? I have been researching it and seen about people making new blocks and offsetting the pin also when it's let back down on its wheels will it centralise a little because one wheel is slightly closer to the arch than the other what a pain lol!
    Apr 2012
    On the down low
    2,107
    9,717
    might have the springs the wrong way round if its nearly touching the front of the wheel arch, worth checking with a tape measure
    Jan 2012
    Oxfordshire
    68
    Quote Originally Posted by mugglesquop View Post
    Yeah i had the n/s spring on the wrong way around first and the wheel wouldnt even go on so i swapped that one around and now the wheel goes on but just sits very close i measured the lengths so theyre now equal but just cant see why one sits further forward
    Feb 2010
    kettering, nothamptonshire
    756
    Please can you tell me what beetle shocks fit please pre????
