Results 1 to 20 of 36
Thread: MK1 Suspension FAQ
    MK1 Suspension FAQ
    Cos I'm bored at work!!!
    A few sections to this one with links to the posts - it'll make sense when you see it.
    Front Suspension:
    Standard Suspension including assembly info / required tools
    Lowered Suspension
    Rear Suspension
    LoweredSuspension
    Chassis Mods
    Strut / Roll bars
    Front Suspension STD
    Main components and their names
    The mk1 golf platform (and mk2, mk3 etc etc) uses a MacPherson strut front suspension setup. This system is used in all sorts of cars by all kinds of manufacturers. The basic components don't change, those are:
    Wishbone / Control arm
    Wheel bearing housing assembly
    Strut /shock absorber assembly
    Track rod /steering arm
    The Wheel bearing housing assembly is the bit not labeled in blue that the wheel bolts on to.
    An exploded view of the front strut for a MK1 Golf/Caddy
    Bolt sizes / tools required listed by component
    Front Suspension Lowered
    Rear Suspension STD
    Rear Suspension STD
    Rear Suspension Lowered
    How do I lower the back of my truck?
    What's an axle flip?
    How do i get negative camber on my rear axle?
    Shock comparison & part nos
    Bolt sizes for stub axle & u-bolt
    Which way round a spring goes
    I've flipped my axle and my wheels aren't central in the arch? – did I make a diagram of that?
    How to centralise my axle
    “Bodges”/how not to do it
    Comparison of block/wheel combo
    Chassis Mods
    For when your truck is just sooooooo low you need to take bits away or move things to get that extra clearance!
    Notching the chassis legs
    What is notching and why would I want to do it?
    I want to notch my chassis legs - how do I do it?
    Raising the turrets
    What is a raised turret and why would I want it done?
    Answer by Mugglesquop
    Raised turrets allow more suspension travel, so allow you to go lower if you have run out of adjustment on your coil overs. You are raising the mounting point for the top mount, so the suspension is mounted higher than normal thus bringing the wheel up closer to the arch.
    The raised topmount allows the suspension more room to move vertically and work more naturally. It will change the angle of your wishbones and driveshafts. So can put extra strain on the other suspension components, not a mod to be done in isolation!
    some pics...
    Alistar's raised turrets:
    (From: http://vwcaddyforum.com/showthread.php?t=4368)
    Drew's raised turrets:
    (From: http://vwcaddyforum.com/showthread.php?t=7706)
    Strut / Roll bars
    Extra post for expansion
    Extra post for expansion2
    Extra post for expansion3
    15,641
    ooh! something to do today
    Some ideas
    Why does my axle flip loose my wheel position – did I make a diagram of that?
    Slightly exaggerated, but to make it clearer....
    The red circle is as standard, and when you flip the axle it moves to the blue circle and scrubs at teh top front. Centralising it put is back to the green position in the centre of the arch.
    Some Dodgy mods/fixes to watch out for:
    Incorrect Axle flips - Saddles welded on wrong, locating pin/bolt missing, u-bolts replaced with threaded rod
    [IMG]Attachment 11253[/IMG] [IMG]Attachment 11254[/IMG] (thanks to thiggs)
    Dodgy camber mods – mis-matching washers stuffed between axle and stub axle to give “stance”
    [IMG]Attachment 11255[/IMG] (thanks to motobruce)
    Quote Originally Posted by pre67 View Post
    I've got understeer/oversteer - how do I sort it
    Standard suspension geometrys
    How to set camber
    you damn skippy
    Questions and answers please chaps!
    just mk1 in this FAQ - will do a mk2 later
    15,641
    Quote Originally Posted by Dub_Monkey View Post
    you damn skippy
    OK - something to prevent me from drawing some road designs then!
    9,717
    i'm bored at work all day if you wanna give me summit to do
    (in the middle of flipping axle as well - front coilovers yet to do)
    Quote Originally Posted by mugglesquop View Post
    well you can see the style of what i'm trying to write. Short, direct questions with succinct answers to avoid people getting bored and not bothering to read it!
    Any questions I haven't covered above and any answers you can write would be awesome - with supporting pics if possible!
    9,717
    Raising the turrets
    Raised turrets allow more suspension travel, so allow you to go lower if you have run out of adjustment on your coil overs. You are in effect raising the top mount, so the suspension is mounted higher than normal.
    some pics...
    some pics...
    Code:
    Code:
    that's the way to do it!
    9,717
    cheers
    Mk1 Golf GTI front suspension:
    (From: http://www.declangrady.com/gti/technical/index.shtml)
    same (or near as) caddy?
    Feb 2008
    Alberta, Canada
    1,937
    Do all Mk1 Golf Variants (Caddy, Golf, Cabrio) use the same suspension struts?
    Do all Mk1 Golf Variants (Caddy, Golf, Cabrio) use the same front wheel hubs?
    BBB
    I saw two rabbits in a field the other day..... I'm going to call at the house and see if they're for sale
    Then let the teardown begin
    Kingston
    17
    Putting 15inch bbs on the front, Whats the best amount to lower it?
    Hey im nun to mk1 pickups but have fallen in love with them and getting one in the next couple of days and first thing i wanna do is lower it, flip axle i can do but what is the recommended suspension on the front for 15inch bbs? See what i mean Nun. ha
    May 2011
    Swe
    18
    Since I don't own a caddy just yet I can't really get a hang of this kit :
    http://www.justcaddys.com/complete_m...ering_kit.html
    How does the brackets work? And which method is the most proper one to do?
    // Caddy 1.8GT 1989
