Results 1 to 5 of 5
Thread: caddy van lowering
    Sep 2009
    london
    55
    caddy van lowering
    right hi every one ,i am new to the vw game so will be asking a lot of questions lol
    i have just brought a v reg 1.6 caddy van
    few questions
    1. what do they call it and what other model stuff is changeable
    2 . the main one ,at some point i will be doing a sound install but want to lower this silly whats the best thing to use
    the kit in the shop or try and get a airbag kit
    thanks
    Nov 2006
    Between a rock and a hard place
    1,533
    Quote Originally Posted by dips346 View Post
    few questions
    thanks
    These questions have been covered before many times in some cases. I once had a 3000watt system in a caddy van and the weight of the sub boxes brought the back end of the caddy down without any lowering kit!! What sort of size are you thinking? For everyday use the kit is better than bags probably with shackles on the back to sort out a good height. If you do a quick search there are a fair few bits that are interchangeable with the caddy van. The easiest being a polo classic 6k chassis. Your van is a 9k chassis caddy van
    All my life ive been searching for somthing,somthing never comes never leads to nothing
    staffs
    328
    you need to flip the rear axle on a caddy, as above have a search about loads of info on the forum
    Sep 2008
    Bristol
    394
    Mine's rolling about 500-600kg of audio in the back...axle flip without shackles was way too low to drive. Axle flip with extended shackles is just about OK
    -------16 x 12" JBL GT5s --------4 x Starsound S1D-5800
    --4 x 8" PA mids + tweeters-------- 1 x RF Power 800.4--------
    ---------------210a alt --------5 x Dynasty 93ah batts
    151dB (dBdrag), 149dB @ 20Hz
    Sep 2009
    london
    55
    thing is not sure what i am going to do with it 100% yet but would have liked a option of setting ride height if outer plans change in the future ,hence why i was thinking about coilovers or air for the rear
