Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 51
Thread: MK1 caddy Gearbox FAQs
    Quote Originally Posted by brennon View Post
    What gearboxes fit the 1.8 turbo?
    Any 4cyl VW gearbox will fit with the associated flywheel/clutch.
    If you can't use the original box then a mk3 16v gearbox/flywheel with VR6 clutch is supposed to be a good bet.
    A tricky question to categorise, it's both engine and gearbox related.
    Monkey
    Quote Originally Posted by Dub_Monkey View Post
    Thank you, now answer the other question that came up recently
    "Can I fit a GTI gearbox to my 1.6D"
    I'm fairly sure it can - I think a couple of folk here have, but it's not really ideal from what I remember - E.g. good acceleration but runs outta revs too quick!
    I *think* umpderdunk has the first 4 gears GTI and 5th from a diesel to get best of both
    Haslemere, Surrey
    1,277
    where can i get the 5 speed linkage rods?
    euro car parts are listing them on their website!
    long rod - Part Number: 650440360 £7.64
    short rod - part# 650440340 £7.04
    Sep 2008
    Reading
    459
    Does anyone know what gearboxes the RA/SB 1.6TD engines came with? And whether they are 020 or 02A?
    They were in 88-93 B3 passats, 89-91 Golfs/Jettas.
    Quote Originally Posted by Bobby505 View Post
    Both I think!!!
    Passat will have 02A and golf/jetta will be 020.
    Oct 2006
    Kristiansund Norway
    2,010
    020 gearbox
    Here's an 020 box
    What ever the code there are very little external differences. You'll see in the picture that this box has a 2 pin reverse light contact. Some boxes have a larger electrical connection for the later MFA 'driving computer' system. This is a 2Y code from a mk2 gti 16v. This box has 100mm outputs.
    A very easy way to see the difference between a 4 and 5 speed is the 5 speed will have the 'green' end cap..... the 4 speed has a square alloy end plate.
    Steve
    Oct 2006
    Kristiansund Norway
    2,010
    How much oil ?
    Just like your engine, your gearbox needs oil too but with the gearboxes we have there is no easy way to tell the oil level. So.... the only sure way is to drain the box completely and then re-fill
    Capacities are
    4 speed 1.5 litres
    5 speed 2.0 litres
    S
    Oct 2010
    Redruth
    34
    Any one have any pictures of the drain and fill plugs on a four speed 1988 diesel box?
    Mar 2007
    near Disney in France
    492
    020 4T (at least for the golfs) 90mm driveshafts
    some passats had the 020A (cable shift) and some had the 020
    Apr 2008
    under a car
    30
    Quote Originally Posted by KernowCaddy View Post
    here you go
    http://www.brokevw.com/020oil.html
    Aug 2010
    Isle of Wight
    333
    I've got a question -
    "How do i solve a sticky first gear?"
    [edit - does the standard mk1 4 speed box have a synchromesh for 1st?]
    and maybe a useful tip
    suddenly find no reverse gear or first gear? - check the smaller linkage in the engine bay on top of the gearbox as the clips on ball-joint cup holders on mine wore out, if you clip it back on with a fresh linkage thingy it all works again fine
    May 2010
    San Diego, CA. USA
    219
    Q: Why can't I remove the driveshaft bolts with a Allen key?
    A: Because the bolt has a spline head
    Attachment 11163
    In America, you may also find this referenced as a "Triple-square".
    Here is one place that sells them as a set.
    1970 VW Bug
    2002.5 VW GTI VR6 24v
    1981 VW Caddy 1.6D
    sheffield
    367
    Clutch compatibility AAZ TD with Scirocco box
    Hi
    I'm having a AAZ TD lump fitted to my MK1 next week.
    Does anyone know if my MK1 Gti 200mm clutch will fit the flywheel on the 1.9 TD?
    We've not removed the TD gearbox yet to fit my scirocco 4+E box and drive shafts, but spec sheets on the TD are saying it uses a 210mm clutch.
    Will this cause me any problems or is it a straight fit?
    Does the 10mm difference make all the difference?
    Traveller
    Quote Originally Posted by traveller View Post
    Hi
    Traveller
    Fairly sure the AAz has an 02A gearbox and the scirocco one will be 020 so it's not going to fit.
    If you want the scirocco box you'll have to fit the scirocco flywheel too
    sheffield
    367
    Quote Originally Posted by DubMonkey View Post
    Thanks. That makes sense :-)
    sheffield
    367
    I've just found more info in 13's diesel engine swap thread.
    Sorry guys for not seeing it earlier :-)
    Aug 2009
    Hertfordshire
    84
    Hi, need a bit of help please?
    I've read the stuff baove and just need some clarification.
    I had the gearbox reconn'd last year, and its had to go back as the diff has slack, I'm outsside of the guaratee, but now I'm told the driveshafts are wearing the housing. I kinda wonder if this should have been picked up by the gearbox people before taking the cash, but hey this is where I am at.
    Its a 5 spead box (he said it was a very very early one) I read this quote above:
    "Q: I've fitted an 020 5speed gearbox and now my driveshafts don't fit, what's going on?
    A: You may have an 020 with 100mm output cups/flanges. These were fitted to later mk2 golfs and mk1 carbios, these were never std fitment on caddys.
    See 100mm Vs 90mm for more info "
    Have checked the 90 vs 100mm and I'm none the wiser.
    What do I do? What gearbox do I need.
    Its a diesel if that makes any difference?
    Thanks in adv
    (Aethel's gone, the old blue jalopy '89 wants to be as beautiful in the long run....)
    Sep 2005
    oxfordshire
    2,557
    thaught id dig this up... reading up on some installs and wondered what sort of power the 90mm shafts on a 020 box can take thinking g60 power?
    sheffield
    367
    Here's a good question for you!
    Will a Golf MK1 3 speed AUTOMATIC box run OK with my AAZ Caddy MK1? :-)
    Jun 2013
    Sheffield
    12
    How can I get a generic caddy speedo to work with a o2k gearbox? I can't find any information on the o2k and new to this
    Thanks in advance
