Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: V-Maxx Coilovers vs Budgets comparison
    Sep 2009
    manchester
    668
    was really hoping it would sit exactly the same height is this the same with all coil over kits as I think it may look daft if the front goes down any more as it already sits tail high
    Which spring rate are the VMaxx?
    Can you get different spring rates?
    Jul 2014
    NOTTINGHAM
    19
    Hey
    How much thread should I use on the top of the vmaxx when fitting to the top mount ?
    Quote Originally Posted by hartland_12 View Post
    Hey
    All of it, the nut should tighten down to the bearing. Make sure the bearing spacer is fitted otherwise it will crush the bearing and bind up
    Jul 2014
    NOTTINGHAM
    19
    Top banana ! Just gathering the info b4 I start
    Mar 2015
    Sunderland
    35
    Lads, what will be the best coilovers for my caddy pick up mrk 2
    DVid
    best for the money are probably still vmaxx, theres better out there for more dosh, or there is the cheap chinese rubbish
    Jun 2015
    San francisco
    94
    I seen oem springs and struts. Springs made in Sweden.
    If you weren't going lower what would be a better ride
    New Struts and springs or vmax coil overs?
    Im guessing the new oem will last another 275k
    Jul 2015
    Essex
    2,125
    If you want a better ride then standard issue would be best coil overs will make it harsher
