Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 60
Thread: Engine FAQ Suggestion thread
    Right peeps
    We're all agreed that well formed FAQs will help everyone out. Making it easy for the newbies to find the answers and less repetitive for the old codgers, I mean old hands amoungst us
    So can we please have suggestions fo the questions often asked listed in this thread.
    I want questions ONLY to start off with. Once we have those we can go about answering them and linking in the good content lurking in the depth of the caddyforum!
    This is not a discussion forum, please don't post about how a good an idea FAQs are. Just well formed, popular, high level questions of an engine nature please. I've put a few below to get us started.
    Monkey
    Q: What engines fit?
    A:
    Most 4 cyl engines 1.6 or larger from Mk1 / Mk2 / Mk3 Golfs will bolt in using the right Mk1 Golf mounts and require no modification to get them physically into your truck. Physically placing the engine is only half the battle though. Full answers click here
    Q: Can I fit a petrol engine in my diesel caddy?
    A: Yes you can, see Which diesel engines fit FAQ for more details. Also see Fuel system FAQs for advice on tanks and fuel lines
    Q: Can I fit a diesel engine in my petrol caddy?
    A: Yes you can, see Which petrol engines fit FAQ for more details. Also see Fuel system FAQs for advice on tanks and fuel lines
    Q. How do I change fuel lines and pump for a Gti conversion?
    Q. What exhaust will fit my replacement engine?
    Q. How do I install and set up my diesel pump?
    Q. What special tools do I need to replace the timing belt on my caddy?
    Q. How do I convert to a Weber 32/34?
    Q: What is an engine code & where do I find mine?
    Q:Which petrol engines fit?
    A: First lets define the term fit. FIT in this instance means the engine block will bolt in using std Mk1 engine mounts with zero chassis modifications.
    This has been split into engine architecture and engine code to hopefully make it easier to read.
    8V
    DX
    JH
    16V
    KR
    PL
    9A
    ABF
    Q:Which diesel engines fit?
    Normally Aspirated
    Turbo Diesel
    Q: what does a Eco pump look like and how do i tell if i have one?
    Will revamp my previous efforts to a more consise manner - as i said
    Q: how do I swap 4speed to 5speed?
    Quote Originally Posted by 13ad13oy View Post
    Thankyou mate
    Popular: yes, Well formed: yes, High level: yes, About engines: no!
    Will move that over to the gearbox FAQ although it could still have a place in the engine FAQ for the newbies that don't realise the gearbox and engine should be discussed separately
    I HATE it when people mis answer posts because they don't read them properly
    Awwwww
    Title changed to make it easier
    Sep 2005
    Custardland Devon
    868
    Any good for a start monkey?
    Quote Originally Posted by jester View Post
    S'all good, keep em coming
    9,719
    Q. what the hell does the code on my engine mean?
    Q: where can i find an engine number (On block & on Docs) (Monkey in the FAQ i made there is a pic of reg doc you can use)
    Q: (although a hard one to answer) how do I make my engine faster
    Jan 2008
    Rockland, Norfolk
    1,294
    How do i remove my engine?
    Can i put a 1.8i head on my 1.6 petrol caddy engine?
    Can i put a turbo on my 1.6 diesel caddy engine?
    How do i protect my sump, once i have slammed it?
    Looks like a pick up, drives like something else!
    Mar 2007
    near Disney in France
    492
    how specific do you want to go? Like: Does a GTD pump fit on a AAZ?
    Can an AAZ head fit a 1.6TD block? and so on ...
    I want to keep them high level to start with.
    once we have a good base then we can do other FAQs like Diesel pumps and interchangable parts etc.
    Those might be better off as how tos though
    Monkey
    May 2009
    NorthWest
    332
    like i asked the other day...
    "how fast is an aaz or gtd? how fast in comparison to KR or ABF?"
    im sure someone else will want to know.
    delete if not neccessary.
    Jan 2008
    Rockland, Norfolk
    1,294
    Quote Originally Posted by Bartman View Post
    Perhaps a list of engine codes, and bhp etc figures would be good for engines, used for conversions
    Quote Originally Posted by veedubbleya View Post
    Right What I'm thinking of for a format is one or two lines max for the short answer and then a link to a post further down the thread with the full answer and content rich links.
    So please feel free to answer the questions already posed and I'll format the 2nd post to suit.
    thanks
    Monkey
    A: Most 4 cyl engines 1.6 or larger from Mk1 / Mk2 / Mk3 Golfs will bolt in using the right Mk1 Golf mounts and require no modification to get them physically into your truck.
    This also applies to 4cylinder engines from most VAG cars from similar desgin eras. eg Passats, Corrados, Jettas, Audi 80s, SEATs
    To check specifics regarding fitting your engine try searching on the engine code. See what is an engine code FAQ. {link to FAQ}
    There are exceptions to this rule, a G60 engine doesn't bolt straight in although the custom mount you need is easy to fabricate if you can weld.
    Don't forget with enough time/money/passion/skill/luck?/determination anything can be made to fit. Also some off the shelf mounts are available to allow later Mk4 engines to be fitted. 1.8Turbos for example.
    With any engine conversion once you have it physically mounted you still have to think about the following:
    Fuel management, be it carbs or injection
    Spark management, (petrol only) mechanical dizzy or ECU controlled
    Exhaust, due to the lack of space the choice of manifold/downpipe can be very limited for a Mk1
    Other engine FAQs
    A: First lets define the term fit. "Fit" in this instance means the engine block will bolt in using std Mk1 engine mounts with zero chassis modifications.
    The Mk1 caddy engine bay is the same as a Mk1 Golf engine bay. The Golf came with either small block(1.1 & 1.3) or big block (1.5,1.6,1.8 & diesel) engine mounts. All Mk1 Caddys have big block engine mounts from the factory.
    This list been split into engine architecture and engine code to hopefully make it easier to read.
    8 Valve engines. These are probably the easiest to use as VW have done all the work with the Mk1 GTi and there's loads of aftermarket parts available to help with your conversion.
    DX
    JH
    16 Valve engines
    KR
    PL
    9A
    ABF
