Page 3 of 18 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 41 to 60 of 355
Thread: Vr6 Caddy project!
    Jan 2009
    motherwell , scotland
    473
    The master cylinder/servo will have to be removed and the brake lines moves to the side to allow me to refit the engine.
    Jan 2009
    473
    Cut a nice heat sheild from stainless sheets a had laying in the garage to protect the wiring harness from the exhaust.Also cut a one and fitted it to the tunnel to protect the gear selector cables.
    Jan 2009
    473
    Fitted the Vr corrado rad, had to cut a small piece from the landing panel to fit it properly.
    Jan 2009
    473
    Fitted all the wiring harness to fuse box. Dash loom / engine loom to fuse box.
    Jan 2009
    473
    I cut the Mk3 Golf fuse box hangers from the dash support and welded into place on the mk1 dash, forgot to take pics of this, fits a treat.
    Jan 2009
    473
    Jan 2009
    473
    Trial fitted the Vr6 Golf clocks/indicator/wiper stalk to the Polo 6n dash, and flung on an old passat b3 wheel to check for clearance, sorted.
    Jan 2009
    473
    Found an old Polo in the scrapyard with electric windows, so set about removing the dash loom.Split the loom to remove whats required for the caddy.
    Jan 2009
    473
    After 20 min, this is all thats needed from the Polo 6n loom. All taped up and ready for fitting,
    Jan 2009
    473
    Help needed. Ive found 2 plugs on the wiring harness which i cannot locate to the dash loom/engine loom or fuse box, does any one know what there for, are the required or are these just spares. Im thinking they might be something to do with the ABS as i removed all this as im not fitting it. Any feed back would be appreciated. cheers.
    Jan 2009
    473
    They are both together with a small ring around them with the number 2 on it???????????????????????????????????????.
    Jan 2009
    473
    Got the lump in now, had to remove the servo and brake pipes, and on the way out, snapped the servo rod return spring!. Anyone help me here, can't get one anywhere!. Your help would be appreciated! cheers.
    Jan 2009
    473
    Well finaly got around to getting some fuel sorted out in the way of a tank trial lol.
    1st one's the old Golf Vr6 tank. (too big lol)
    2nd is a 6n Polo 1.4 16v tank with the Vr6 pump and sender installed.
    3rd is a 1.4 16v Lupo tank .
    I had the Polo tank fitted and was quite happy with it, until i lowered it back onto it's wheels and the end of the tank was being crushed with the axel as is has been flipped
    Jan 2009
    473
    So back off with the polo tank
    Jan 2009
    473
    Removed the Pump and sender from the Lupo tank.
    Jan 2009
    473
    Fitted the Vr Pump and sender too the Lupo tank, fit's a treat.
    Jan 2009
    473
    Don't know if it's been done before but it's not far away.
    Jan 2009
    473
    Just have to make a filler pipe to go from the Caddy's filler too the Lupo filler, fit a Polo 6n fuel filter from the pump feed and it should be fine.
    Jan 2009
    473
    Here's a pic off all 3 pump's n sender units together.
    :not the difference in size too the Vr Pump and sender, but the Polo & Lupo/Arosa are spring loaded and press down too the same size as the Vr, sorted.
    Jan 2009
    473
    Pic of the back in the engine bay:
