Results 1 to 20 of 38
Thread: AAZ pump timing
    Mar 2009
    Isle of Wight
    1,136
    AAZ pump timing
    How do i time the aaz pump up? I read the haynes book of lies, and it said to dti gauge the end under the sensor?
    Got a mate with dti gauge so just after advice on best method
    Thanks in advance
    17,856
    up to TDC on crank (flywheel mark)
    fit DTI gauge preloading the needle about 2mm
    turn crank backwards about 1/16 - 1/8 of a turn and watch DTI
    DTI should go back about 1mm ish then stop moving
    zero the reading on the DTI
    bring crank back up to TDC
    what you read on the gauge is your timing setting or 'lift'
    think it should be 0.9 or 0.95 on an AAZ
    adjust pump pulley to get it right.
    turn the motor over a couple of times and recheck.
    15,312
    I could do with buying a DTI - anybody recommend me one/a kit?
    Mar 2009
    Isle of Wight
    1,136
    thanks reg, il print that out
    Mar 2009
    Isle of Wight
    1,136
    is this pump TDC???
    9,721
    Quote Originally Posted by 13ad13oy View Post
    Moore & Wright are good DTIs ebay second hand
    17,856
    is this pump TDC???
    that'll do...
    Jul 2006
    Huddersfield
    2,441
    i had a gay AAZ pump like that, i got a GTD pump off reg instead! lol
    MK1 VW Caddy - 1.9 GTD - K14 turbo - GTD pump - FMIC - 2.5" straight through exhaust - smokin' !
    Mar 2009
    Isle of Wight
    1,136
    sweet, thanks guys, new cambelt going on today as nicked old 1 with grinder oops
    17,856
    Guess who ended up with the gay pump?
    Jul 2006
    Huddersfield
    2,441
    you wanted it! lol
    Oregon, USA
    92
    You need to use the TDC mark on the flywheel, not on the injection pump.
    There should be a cover you can look through. See the blue circle on this photo.
    http://www.clubgti.co.uk/forum/showthread.php?t=26910
    I'm running the old non-turbo 1.6 liter engine.
    According to my Bentley Manual, there were two ranges of timing:
    There was "normal" and "improved performance".
    The "improved performance" had slightly more needle travel on the indicator, which I believe means a couple of extra degrees of timing advance BTDC.
    According to this chart, NOx increases slightly with advancing the timing, but most other factors are improved including a decrease in Brake Specific Fuel Consumption (BSFC)
    http://www.oliverdiesel.com/tech/timing.htm
    I am kind of rough on my idle so I may play around with it a little more.
    Oh, one last hint...
    The third bolt holding the injection pump on is accessed from the timing belt side of the engine. I had half the engine taken apart and was cursing everything VW before I realized this.
    17,856
    Clifford, the NA 16 and the TD16 and some early AAZ engines are all different to this AAZ pump.
    They mount up different and they time up different.
    15,312
    Still not got one yet - How much travel do i need? also do i need an adaptor or anything?
    thanks
    9,721
    you get two different (common) types of DTI - Finger and Plunger
    Finger type are more acurate, but u only get a limited amout of travel (around 5mm) where as plunger type can have around 30mm travel with the same size DTI
    15,312
    Can anubody comment if this is worth getting?
    Or a DTI gauge pluse these?
    Oct 2008
    Exeter
    373
    15,312
    Thanks for the link but look at the price! (Call me tight, but I am scottish!)
    17,856
    Mr Baxters prices are a bit excessive. £17 for a locking bar!
    I paid less than £30 for my second hand DTI and adaptors via ebay UK
    15,312
    Well got me a DTI:
    I bout it from USA, @ £33 delivered including the adaptor.
    Then lovely customs gave me a nice £13 charge when it arrived!!
    So it was nearly a bargain.
    Just need to sus out how to operate it now
