Page 75 of 76 FirstFirst ... 25 65 73 74 75 76 LastLast
Results 1,481 to 1,500 of 1503
Thread: Worthingcaddys Mk1 VR6 Turbo
  1. #1481
    4,491
    Thanks mate, it's VHT wrinkle paint. like yourself i'm anti bling too i just haven't got round to it. planning on painting the lips of my wheels black too
  2. #1482
    Will give it a go! I have looked at crinkle powder coating too !!
  3. #1483
    4,491
    the main thing with the crinkle paint is make it as hot as possible! literlally have the heater on it constantly, as close as possible. and heat the fuck out of the part beofre you lay the paint on too
  4. #1484
    Ok will give it a go, heat gun on the ready
  5. #1485
    Heat gun wont help much as it just dries the outside leaving the inside squidgy, which never dries properly. Whatever you paint need to be hot and kept hot until its baked on.
    With something like boost pipes, your better of closing one end with aluminium foil with some pencil holes punched in it, and run the heat gun on the inside at the other end
  6. #1486
    4,491
    The alloy pipes were too hot to pick up by hand before I started putting the paint down. I then sprayed it on, then had the heater sat on it until it was dry. You're meant to bake it in the oven but the pipe was too big!
  7. #1487
    Apr 2007
    Bristol
    444
    Quote Originally Posted by worthingcaddy View Post
    My mate used the oven in the kitchen to bake some parts he'd just painted, however he didn't expect the Mrs to come home early and go mental at him and refused to make any meals until he got a new one.
    But at least he's got one in the garage now
  8. #1488
    That was my plan to heat them from the inside. Didn't think about blocking the other end slightly that will help
  9. #1489
    4,491
    Personally, from my experience using crinkle paint id always put the heat directly on the paint. Heating the part first I'm sure helps but once it's warm, it stays warm from the heat being applied on the outside
  10. #1490
    2nd that.
  11. #1491
    4,491
    Update time. i've done a ton of jobs to improve the caddy, first job was sorting my silly wide rear wheels so i don't have any rubbing issues anymore, plus i don't want to run stretched tyre, fitted a swirl pot setup which i'm pretty chuffed with so i don't have fuel starvation problems. The nitrous setup is now all nicely plumbed into the fuel rail using a AN-4 line. Made a new turbo inlet pipe and painted it up and cleaned up that side of the bay, added a carbon pod filter thing, just so it looks fancy. Finally got a brake servo that sits the brake MC vertically rather than on the piss, i used a basic mk3 golf one that i got for a tenner to save on scene tax and modified it to suit. oh and a mate of mine made me a carbon radiator cover. Caddy is booked in at the tuners in just over a week so should see a ton more power.
    here's a load of pics to do the talking, god knows what order they will upload in though
    Photo 25-04-2018, 17 32 16.jpgPhoto 23-04-2018, 16 23 16.jpgPhoto 23-04-2018, 15 07 35.jpgPhoto 22-04-2018, 19 32 02.jpgPhoto 22-04-2018, 19 30 20.jpgPhoto 22-04-2018, 19 24 00.jpgPhoto 22-04-2018, 19 13 54.jpgPhoto 22-04-2018, 18 38 09.jpgPhoto 22-04-2018, 18 07 04.jpgPhoto 22-04-2018, 18 06 12.jpgPhoto 19-04-2018, 19 37 14.jpgPhoto 13-04-2018, 13 52 15.jpgPhoto 13-04-2018, 10 11 30.jpgPhoto 10-04-2018, 15 08 13.jpgPhoto 09-04-2018, 15 46 00.jpgPhoto 09-04-2018, 11 33 13.jpgPhoto 26-03-2018, 18 20 07.jpgPhoto 25-03-2018, 12 31 51.jpgPhoto 25-03-2018, 12 31 27.jpgPhoto 25-03-2018, 12 09 50.jpgPhoto 25-03-2018, 12 09 42.jpgPhoto 24-03-2018, 12 54 14.jpg
  12. #1492
    4,491
    i'm pikcing up a new set of wheels for the caddy tomorrow so my OZ turbos will be up for sale if anyone is interested
  13. #1493
    I see that on FB! I must admit they caught my eye but I dont have any Caddy funds at the mo.
    Whats the replacements then???
  14. #1494
    4,491
    Got me a set of team dynamics pro race 1.2 complete with Toyo R888R tyres. Turns out I need a standard length axle again though, mines shortened 3 inches each side... don’t suppose you have one do you?
  15. #1495
    Ant, pretty sure I still have mine. its been flipped.
    Drop me a text tmro and I’ll check for you.
  16. #1496
    4,491
    Ah man, that would be amazing! Thanks mate, will do!
  17. #1497
    The only spare one I have is past its best, and its currently being reverse engineered!
  18. #1498
    4,491
    Just finished making up this carbon dash surround
    Also dismantled the clocks and took apart my AFR gauge and fitted it in place of the coolant temp gauge (got my auto meter one in the carbon dash bit)
    Blew the engine in late October so I’ve spent winter rebuilding, booked in for a tune at emerald in a few weeks time. It’s now got forged rods, forged low comp pistons, quaife LSD, 875cc Siemens injectors. Had to have the block bored and various other machining stuff done. But we’re almost there now
  19. #1499
    4,491
    Used these connectors so I don’t have to deal with each switch ever time it comes out. Used the same for the gauge wiring too
  20. #1500
    Hobby turned into a money pit
