Page 60 of 61 FirstFirst ... 10 50 58 59 60 61 LastLast
Results 1,181 to 1,200 of 1202
Thread: Project Caddy VR6 Turbo
  1. #1181
    Jun 2007
    Kendal,Cumbria
    1,644
    Quote Originally Posted by 13 View Post
    Any updates on the, er water injection?
    Haven't updated this in a while have I!
    Yeah update on the water injection, basically where I had had the head welded from the previous melt through it had cracked and sunk right where the head sealed against the bore, hence why there was water getting in there.
    New head on now and all set for gti festival this weekend.
    Time to finish an unlucky season off with a 9 second 1/4!
  2. #1182
    15,468
    Excellent! Glad it's back together
    Good luck my friend!
  3. #1183
    Nov 2008
    Surrey
    2,714
    Awesome, fingers crossed for you mate
  4. #1184
    572
  5. #1185
    Jun 2007
    Kendal,Cumbria
    1,644
    Nothing major to right home about.
    Gti festival didn't go aswell as I would of liked, think I did 4 runs with a best of 10.2 and broke 3 driveshafts so back to the drawing board with them!
    Might of added a touch more safety since then and added some rear stays to the cage.
    I've ordered some slicks for next year so that along with a bit more boost should get me into a 9
    Hoping to rewire the whole caddy aswell as it's got a battery drain and wasn't charging properly, 10 years worth of chopping and changing properly hasn't helped that!
  6. #1186
    572
    would it not have paid to weld the shafts then sleeved them? they appear to have sheared in the same place
  7. #1187
    Nov 2008
    Surrey
    2,714
    no rear window?
  8. #1188
    15,468
    Cage looks great!
  9. #1189
    Jun 2007
    Kendal,Cumbria
    1,644
    Quote Originally Posted by Mike.F View Post
    Yeah I should of but was told just sleeving them will be fine, however he didn't tell me he uses 10mm walled sleeves! These were just 3mm so I'm surprised they lasted so long really!
    Still undecided on what route to replace them with yet.
    V weld and re sleeve them with thicker walled sleeves or custom don octane shafts!
    Quote Originally Posted by blenki View Post
    no rear window?
    Yeah I will be running a Perspex one, just trying to get a nice fit round the tubes is hard!
  10. #1190
    worthing
    4,458
    Quote Originally Posted by slim View Post
    i reckon you could make the shafts up yourself Mike, i made mine years ago and although i'm not running crazy power like you i doubt they would break! save yourself some £££ and have a go!
  11. #1191
    Jun 2007
    Kendal,Cumbria
    1,644
    Quote Originally Posted by worthingcaddy View Post
    What thickness wall are the sleeves on yours Ant?
  12. #1192
    worthing
    4,458
    mine are pretty thick, at least 4mm wall thickness
  13. #1193
    worthing
    4,458
    I ground both ends down to a point first too and welded the fuck out of them then sleeved over the top
  14. #1194
    Jun 2007
    Kendal,Cumbria
    1,644
    I'm thinking maybe V weld them then 2 3mm walled sleeves over the top.
  15. #1195
    Jun 2007
    Kendal,Cumbria
    1,644
    Finally got the rear window in after 4 templates!
    Had to make some little pieces to go over the top of the tubes.
  16. #1196
    572
  17. #1197
    1,559
    Nice work! Looks really neat slim! Chute mount next then
  18. #1198
    15,468
    Wow that worked out well. Was wondering how u would do it
  19. #1199
    Jun 2007
    Kendal,Cumbria
    1,644
    Quote Originally Posted by tontoe View Post
    Yeah there is a good chance I will be running a chute next year.
    Cheers, it turned out better than I was expecting aswell.
    It was an absolute pig to do and to try to get it to fit nicely. Took near 2 hours to fit the seal to the screen and then into the pickup, normally it would be a 10 min job!
    Looks loads better using a stock rubber trim aswell instead of screwing it in.
    It's not 100% water tight though, may have to silicone round the tubes from the inside.
  20. #1200
    Jun 2007
    Kendal,Cumbria
    1,644
    Had another go at making a super strong driveshaft today.
    V welded them first
    Made a sleeve and along with a slit I drilled holes to plug weld it to help reduce twist
    All welded up.
    Going to add another sleeve to it aswell so it will have 2 3mm walled sleeves on it.
