Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 61
Thread: Leaf Spring Clatter! Problem Solved....
    Most Caddys suffer from this annoying clattering, especially when the axle has been flipped
    Later Caddys had rubber mushrooms fitted to stop this problem which was obviously recognised by VW, although most of these have now either been lost or deteriorated and fallen off They are still available from VW for £8 odd plus VAT EACH
    I have been working on a "Poly Bush" version for the Caddy and have now produced a prototype, I plan on making these and making them available here to buy, prices will be approx £15 a set So this is a bit of a feeler to who will be interested in these "Anti-Clatter Bushes"
    Ultimately there will be two types;
    The 1st type (see pics) will be for the earlier Caddys which didn’t have them fitted from factory, that have a 5mm hole at the end of the assister leaf
    The 2nd type will be a direct replacement for the later mushroom type Although the 1st type will also work here with a penny washer
    These are the prototype bushes, I haven’t finalised the actual design yet but it will give you an idea (the white patches are releasing agent).
    Dec 2004
    Hampshire / Surrey Border,GB.
    4,899
    I wanna set ASAP.
    **** Caddyless Vandango ****
    Apr 2005
    Bournemouth, UK
    1,387
    I'll have a set
    Jun 2005
    Torbaydos, The Shire of Devon
    1,932
    Nice one Al
    They look "proper job" Having never driven my caddy in the 2 years Ive had her I dont know if I need them yet lol
    But if I do, I know where to come now
    blackandwhitebmx Guest
    i'll take a set.
    Will state side be able to get them?
    Jul 2006
    devon
    109
    yep i would buy them straight away if you had a set the bangin noise i get from mine does my sweed right in
    Jan 2006
    Middlesbrough, UK
    305
    Yep. I'll have a set. Give me a shout when they're ready!
    the artist formerly know as when_the_angels_sing
    Myspace Profile - See what a dick I really am
    Quote Originally Posted by Bo0stl3aksp3cial
    In theory yes, im not sure of the spring setup in the states, i will look at some pics
    They will be avalable soon lads, i just need to get under my Caddy to finalise the design before I make a batch
    Mar 2005
    leeds at the mo
    564
    im in, to get rid of the clattering would be great
    the return of the joe
    Dec 2004
    4,899
    Hurry, Hurry!
    Apr 2003
    Albany, NY, USA.
    5,454
    I've never had clatter problems. My leaf springs have these nylon sheets in between them, I don't know if they're factory or not. When I added the extra leaf last year I put a generous helping of never-sieze between each set of leafs and haven't heard a peep.
    Garry
    The Truckdoza Lives!!!
    I just looked at some detailed pictures of a US setup and they will not be suitable for that application, in the US you have a "close multi leaf" setup which will have nylon of simular bushings as Darth mentioned.
    In Europe the Caddy was designed to carry more weight so an "assister" leaf was added
    Jan 2005
    Ruislip, Middlesex, United Kingdom.
    1,859
    Al you got any pics of where/how these will mount ?
    Amit
    In my garage
    MK1 Caddy project | 1981 Mk1 G60 | 1978 Golf mk1 | Mk3 VR6 Supercharged | 2005 Merc CLS 320 Daily Driver
    I will as soon as there is a break in the weather as I need to fit the ones above to my Caddy with a little "how to"
    Quote Originally Posted by Amit
    Amit
    Here you go, you can see where the assister spring has made an impression on the main spring over time
    Jan 2005
    1,859
    My assiter springs dont have holes in them..
    and I dont fancy taking them off again..
    I fitted some 2" blocks at the weekend.. what a mission that was!
    Amit
    In my garage
    you wouldnt need to take them off to drill them! Just jack it up and wedge a block of wood between the leaves
    Dec 2004
    4,899
    Have you driven with them on yet, do they work?
    I need!
    TBH I only fitted that one in the cold yesterday for a visual, I was going to do the rest today but its raining yet again
    As soon as I get a dry day I will finish them off and make a batch as I have finished the final design
